whole dashboad not showing on mobile phone only slides right.
Best Multi Vendor Marketplace Plugin for WordPress Forums WCFM whole dashboad not showing on mobile phone only slides right.
Viewing 1 reply thread
    • #11286
      Alex
      when i login into the dashboard on a mobile phone, its slides right instead of center making the whole dashboard and some settings not visible. even when i slide left, the whole dashboard is not visible.
      how can this be fixed. thanks
    • #11287
      WCfM Forum
      Can you please tell us in which mobile you are testing this?
      Frankly speaking it is very difficult to match each and every mobile view as there has lots of different sizes.
      WCfM dashboard mainly desinged for standared mobile screens ( e.g. iPhone 6s Plus).
      Kindle share your mobile model we will difinitely look into it, in fact it will enrich WCfM in a way, thanks for pointing out this.
      If possible please give us a screenshot as well.
  • The topic ‘whole dashboad not showing on mobile phone only slides right.’ is closed to new replies.
