Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM – Membership › Whose percentage is it?
- This topic has 7 replies, 4 voices, and was last updated 7 years ago by
- July 20, 2018 at 1:37 pm #26664
gilservant
ParticipantWhen I create membership I see that the default is 10%. I want to know whose percentage is it. Is it the percentage the admin takes or is it the percentage that the vendor receives?
- July 22, 2018 at 5:54 am #26694
Which multi-vendor plugin you are using? Actually, it’s depending upon multi-vendor plugin’s commission mode.
- July 22, 2018 at 7:36 am #26706
gilservant
GuestI use WC Marketplace
- July 22, 2018 at 8:04 am #26713
MemberThat’s fine, thanks for the information.
Under WCMp -> Payment setting you may set commission mode.
Membership commission works as per that mode as well.
- July 31, 2018 at 9:03 pm #27359
WWW
ParticipantSo in case of Woocommerce marketplace, which setting overwrites the other? Lest say I have WCMP setting of 0.5usd + 5% per order (admin fee) and I have a WCfM set to 10%? How much it is then?
- August 1, 2018 at 6:12 am #27385
Then it will charge 10%
0.5usd + 5% -> This is global rule
10% -> This is vendor wise ruleAlways, vendor specific rule overwrites global rule
After that you may also define commission for each Product.
Then it will overwrite vendor rule.Thank You
- August 1, 2018 at 3:51 pm #27427
WWW
ParticipantThanks for a reply.
So it is not possible for me to set a fixed fee + percentage for all vendor levels? - August 1, 2018 at 4:10 pm #27431
We will add this in coming Membership update.
- The topic ‘Whose percentage is it?’ is closed to new replies.
