Best Multi Vendor Marketplace Plugin for WordPress › Forums › WC Vendors › Why ACF does not work with MULTI SELECT, only radio button (single selection)
- This topic has 9 replies, 3 voices, and was last updated 7 years, 10 months ago by
Shhiv Narayan.
- October 13, 2017 at 6:52 pm #14326
lwifunyo
GuestI have ought WCFM ULTIMATE and im enjoying using itr!
I was added ACF to my products before i boght your plugin,
but I have discovered that it does not support MULTI SELECT even radio buttons work (single selection)Please can you fix this problem as sooner cause vendors are confused with that! Thanks
- October 13, 2017 at 9:11 pm #14327
WCfM Forum
Thanks for get in touch with us and I am glad to know that you very much like that.
Really sorry for this trouble you are facing with Multi-Select, we are looking into this ASAP.
We will definitely add support of that in very near future version.
Thanks for pointing this out.
Shhiv
- October 16, 2017 at 4:50 am #14381
lwifunyo
Guestthanks for your promptly reply.
im waiting fixing and updates very soon!thanks for best support, service and product.
WClovers are lovely!
- October 16, 2017 at 11:33 am #14410
WCfM Forum
GuestThanks for your lovely appreciation ????
WCFM has just updated today but not the fix with this, we will add this feature in next version.
Thanks for your patience.
Shhiv
- October 17, 2017 at 11:55 pm #14511
WCFM 3.2.2 has just released and we have added support for ACF Multi-Select field types.
- October 18, 2017 at 4:59 am #14515
lwifunyo
GuestHello Hi!
I have seen updates! Thanks!I have seen updates in WooCommerce Frontend Manager only, but in Ultimates there is no updates!
Above that,
Maybe i mentioned in wrong way!
I wanted to mean CHECKBOX does not work, even though MULTI SELECT also does not work!in ACF RADIO BUTTON and SINGLE SELECTION work, but CHECK BOXES and MULTI SELECT DOESNOT work!
and what I need as soon as possible is MULTI CHECK BOXES!
Thanks in advance!
- October 18, 2017 at 5:16 am #14516
Shhiv Narayan
MemberOk ok.
There is WCFM Ultimate update also. If you are not getting update notice then kindly once deactivate and re-active license.
WE have added Muti-Select support in this version.
Will add multi-checkbox in next version as well.
- October 18, 2017 at 6:44 am #14518
lwifunyo
GuestYah I have tested!
Multi select work! Great!
Thanks Sir!
- October 18, 2017 at 8:44 am #14519
WCfM Forum
GuestPleasure.
We will add multi checkbox support in next version as well.
- October 23, 2017 at 5:01 am #14718
Shhiv Narayan
WCFM 3.2.3 has just released and it has support of ACF multiple checkboxes.
- The topic ‘Why ACF does not work with MULTI SELECT, only radio button (single selection)’ is closed to new replies.
