wcfm-santa
-361Day -19Hr -11Min -53Sec
wcfm-santa
Wirecard Brasil Oficial split payment
Best Multi Vendor Marketplace Plugin for WordPress Forums WCFM Wirecard Brasil Oficial split payment
Viewing 10 reply threads
    • #87637
      contato.iggdrazil
      Hi, I have a problem regarding the update below:
      = 6.3.1 =
      *Updated – 22/09/2019*
      * Feature – WCFM Marketplace Wirecard (Moip) payment gateway (customer & vendor split payment) compatibility added
      I do the setup on woocommerce, and it can recognize the plugin without problems.
      But when I login as a seller, on the payment screen, the two connection links appear as in the image.
      When you click on any of them the following message appears “Requested access cannot be granted, integration not recognized”
    • #87929
      What are your WCFM and WCFM Marketplace plugins’ versions?
    • #88255
      contato.iggdrazil
      My WCFM plugins’ version:
      WCFM – WooCommerce Frontend Manager – version: 6.3.2
      WCFM – WooCommerce Frontend Manager – Ultimate – version: 6.3.2
      WCFM – WooCommerce Multivendor Marketplace – version: 3.2.4
      WCFM – WooCommerce Multivendor Membership – version: 2.7.2
      in relation to others:
      WooCommerce – version:3.7.1
      WooCommerce Admin – version:0.20.1
    • #88578
      Well, plugins all are at latest version.
      DO yo have any template override?
      Can you please a demo vendor account with us to check this once!
    • #88638
      contato.iggdrazil
      I already put the page in the air to test, you can connect to it and check the problem.
      the page is https://izi2u.xyz
      If you need I can pass a private login and password for you to check.
      thank you
    • #89745
      rocry_anjos
      OLA EU ESTOU COM O MESMO PROBLEMA VC TEVE ALGUMA SOLUCÇÃO?
    • #89748
      contato.iggdrazil
      Por enquanto não tive nenhuma solução do problema, não sei se é algum problema quando faz em sandbox ou se acontece também no modo normal. Só sei que já entrei em contato com a empresa que fez o plugin e me informaram que eles só respondem para sistemas dokan.
    • #90770
      Well, Wirecard integration part of WCFM Marketplace core. No other plugin require for the purpose.
      If you are testing with sandbox account then be sure your Toke is published, other wise it will not work..
      At the beginning we faced same issue and have to contact their support to make this publish – https://dev.wirecard.com.br/discuss/5d7caac3c1a04600309ccd2e
    • #91861
      fcmc3
      I also have the same problem, any solution?
    • #92169
      You have to contact Wirecard support and ask them to publish your token.
    • #92380
      fcmc3
      Wirecard response in Português-BR:
      Oi Fábio, bom dia. Tudo bem?
      Você não está passando o id do APP.
      …&client_id=0&…
      No lugar do 0 deveria estar o código do APP do seu Marketplace (APP-XXXXXXX).
      Wirecard response in InglÊs:
      Hi Fabio, good morning. All right?
      You are not passing the APP id.
      … &client_id=0& …
      In place of 0 should be your Marketplace’s APP code (APP-XXXXXXX).
  • The topic ‘Wirecard Brasil Oficial split payment’ is closed to new replies.
