Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM – Ultimate › Wirecard /Moip/
- This topic has 7 replies, 5 voices, and was last updated 6 years, 5 months ago by
- September 30, 2019 at 11:24 am #84477
todor.ganchev
ParticipantWhich is the official site of Wirecard / Moip / and which plugin should be installed in order to use this payment gateway?
- September 30, 2019 at 12:12 pm #84493
Well, this is WCFM stand alone integration, no other plugin require to use this.
This is a Brazilian payment gateway – https://www.wirecard.com/
- October 10, 2019 at 7:04 pm #86031
contato.iggdrazil
The wirecard plugin has made an upgrade to split payment on woocommerce and I want to take advantage of the feature on wcfm, I wonder how I can do that.
You must be logged in to view attached files. - October 12, 2019 at 1:30 pm #86493
Well, WCFM Marketplace Wirecard integration standalone solution.
No other Wirecard plugin require for this.
You just have to enable this from WCFM Admin Setting -> Payment Setting -> setup credentials
Now, connect vendor account from vendor setting panel.
- October 17, 2019 at 3:53 pm #87370
B123456
ParticipantThis reply has been marked as private. - October 18, 2019 at 10:24 am #87526
MemberYeah, WCFM Marketplace has this in-built.
- October 31, 2019 at 1:07 am #89746
rocry_anjos
ParticipantBOA TARDE! FIZ TODOS OS PASSOS E NÃO CONECTA A CONTA DO FONECEDOR no painel de configuração do fornecedor.
COMO DEVO PRECEDER? - November 6, 2019 at 12:43 pm #91057
Please be sure your Wirecard Token is already published!
If not, then you will not able to use this.
We also had same issue at beginning and have to contact Wirecard support and then they publish our Token for test – https://dev.wirecard.com.br/discuss/5d7caac3c1a04600309ccd2e
- The topic ‘Wirecard /Moip/’ is closed to new replies.
