Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM – Marketplace (WooCommerce Multivendor Marketplace) › Withdrawal charges issue
- This topic has 6 replies, 2 voices, and was last updated 7 years ago by
- August 27, 2018 at 6:38 am #29829
d-n-13
Thank you for updating the withdrawal system it is much better now.
It needs 2 more fixes though :-
1- Make vendor see their requests while it’s pending : https://www.dropbox.com/s/zbjqxg0cnt7fhs0/withdraw%205.JPG?dl=0
2- Charges in the table will show wrong calculation [but at request the calculation is correct]
My withdrawal charge is 7.30
Vendor had 2 orders, when he try to request it shows 7.30 for each, when he requested it calculated 7.30 for both, as Admin I canceled the request.
After canceling the request now Vendor see each order with 3.65 (the correct charge split for each order).
a 3rd order was received and now 2 first orders shows 3.65 and 3rd order shows 7.30, this will confuse vendors
Screenshots :
https://www.dropbox.com/s/nl4m8lyxllv08uu/withdraw%203.JPG?dl=0
https://www.dropbox.com/s/2ew23cb1lzbj03v/withdraw%204.JPG?dl=0
Suggested Solution ?
1- Remove the charges column from and add notice above or below showing the current charges for each gate just like Dokan (you already have notice below but doesn’t include charges such as 0.30$ or 0.5%)
2- Show charges on the request before or after sending just like this https://www.dropbox.com/s/zbjqxg0cnt7fhs0/withdraw%205.JPG?dl=0
Or fix it the best way you think is best.
- August 28, 2018 at 4:02 am #29905
We know this is a bit confusing and that’s why we have added a message under the table.
Though, we are thinking to remove withdrawal charge column from withdrawal table!
- August 28, 2018 at 4:51 am #29912
d-n-13
“Though, we are thinking to remove withdrawal charge column from withdrawal table!”
That’s great, and if you let vendors see their pending request it would be even better.
- August 28, 2018 at 7:06 am #29916
“That’s great, and if you let vendors see their pending request it would be even better.” – off course then can see this. Go to vendor’s payment menu -> By default it shows “Approved” transactions, but there is filter at top to check “Processing (these are pending or requested ones)” and “Cancelled” requests.
- August 28, 2018 at 7:53 am #29921
d-n-13
That is true, sorry I didn’t notice it. Can I make default “Show All” ?
- August 28, 2018 at 5:13 pm #29992
MemberOK, will add prohibition for that.
- September 2, 2018 at 8:43 am #30488
Kindly add this code for the purpose –
add_filter( 'wcfm_payment_default_status_type', function($default_status) { return ''; });
Well, this will work after WCFM next update.
- The topic ‘Withdrawal charges issue’ is closed to new replies.
