Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM – Feature Request › WooCommerce Accomodation Bookings
- This topic has 5 replies, 3 voices, and was last updated 6 years, 2 months ago by
- June 4, 2019 at 10:20 am #65846
Vjean
ParticipantGetting this error since the last update:
Warning: Declaration of WC_Product_Accommodation_Booking::get_blocks_in_range($start_date, $end_date, $intervals = Array, $resource_id = 0, $booked = Array) should be compatible with WC_Product_Booking::get_blocks_in_range($start_date, $end_date, $intervals = Array, $resource_id = 0, $booked = Array, $get_past_times = false) in /clients/wwweasyc/easyclickmarket/wp-content/plugins/woocommerce-accommodation-bookings/includes/class-wc-product-accommodation-booking.php on line 12
EasyClickMarket.com
- June 4, 2019 at 5:14 pm #65904
Craig
Participant@Vjean – do you recall which particular plugin update you did that this error showed up? Was it a WooCommerce plugin or WC Lovers?
We are experiencing this error on our website as well and so far have identified the Accommodation add-on to be the culprit but we did a bunch of plugin updates at the same time.
- June 5, 2019 at 12:20 am #65940
Vjean
ParticipantThe issue was with the WooCommerce Accommodation Bookings. They released a plug-in update and it works fine now.
- June 5, 2019 at 2:45 am #65943
Craig
ParticipantExcellent. I have updated the Accommodations add-on plugin and the error is gone as well.
Thanks for the update.
- June 5, 2019 at 5:17 pm #66024
MemberThe issue was with the WooCommerce Accommodation Bookings. They released a plug-in update and it works fine now.
– Accommodation plugin was not compatible with WC Bookings 1.14, so this error was happening.
- The topic ‘WooCommerce Accomodation Bookings’ is closed to new replies.
