Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM – Marketplace (WooCommerce Multivendor Marketplace) › Woocommerce advanced product labels with Flatsome Theme
- This topic has 3 replies, 3 voices, and was last updated 6 years ago by
- August 18, 2019 at 1:55 pm #77191
Mike_H
ParticipantI’m using Woocommerce Advanced Product Labels as per your compatibility matrix.
I’m going to be replacing the current theme I am using with Flatsome, and on the product categories pages the label shows on the text block under the image instead of over the image as it should do.
I wondered if you had a piece of code to sort this as you recommend both the theme and the plugin?
If not, I’m happy to use the Flatsome “Sale Bubble” but this section does not show up in the Vendor edit product pages, do you have some code to show this section, entitled Extra in the Woocmmerce back-end?
- August 20, 2019 at 8:46 am #77472
Yeah sure, that is possible using WCFM Custom field – https://wclovers.com/knowledgebase/wcfm-custom-fields/
You have to create such custom fields – https://ibb.co/Tkc6x9F
And add this code to your site –
function wcfm_flatsome_custom_field_group_data_save( $group_value, $group_name ) { if( $group_name == 'wc_productdata_options' ) { $group_value = array( 0 => $group_value ); } return $group_value; } add_filter( 'wcfm_custom_field_group_data_save', 'wcfm_flatsome_custom_field_group_data_save', 50, 2 ); function wcfm_flatsome_custom_field_group_data_value( $group_value, $group_name ) { if( $group_name == 'wc_productdata_options' ) { if( $group_value && is_array( $group_value ) && isset( $group_value[0] ) ) { $group_value = $group_value[0]; } } return $group_value; } add_filter( 'wcfm_custom_field_group_data_value', 'wcfm_flatsome_custom_field_group_data_value', 50, 2 );
- September 20, 2019 at 7:52 pm #82669
Mitchell Gould
ParticipantI’m confused. Flatsome already creates the custom tab in wp-admin on the product page. I have to recreate all those fields manually in WCFM?
- September 22, 2019 at 1:06 pm #82903
MemberIf you require those fields then only create.
