Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM – Feature Request › WooCommerce Booking & Reservation Plugin
- This topic has 5 replies, 4 voices, and was last updated 5 years, 6 months ago by
- September 3, 2019 at 11:48 pm #79878
Oksana Grishchenko
ParticipantHello
I have WCFM Ultimate with all its addons. I like to know is WCFM compatible with “WooCommerce Booking & Reservation Plugin developed by extendons” in this link:
codecanyon.net/item/woocommerce-booking-reservation-plugin/23061098?s_rank=20This plugin is 5 times cheaper than “WooCommerce Bookings Developed by WooCommerce” and with more functions and options.
Is it possible to make it work with your plugins?
- September 4, 2019 at 9:37 am #79976
Sorry, WCFM not yet compatible with this one yet!
WCFM compatible booking plugins are –
https://woocommerce.com/products/woocommerce-bookings/
https://bizzthemes.com/plugins/woocommerce-appointments/
https://codecanyon.net/item/rnb-woocommerce-rental-booking-system/14835145
https://tychesoftwares.com/store/premium-plugins/woocommerce-booking-plugin/We are going to add compatibility for this as well – https://www.pluginhive.com/product/woocommerce-booking-and-appointments/
- September 6, 2019 at 11:35 am #80386
patrick
ParticipantRecommend that you consider adding support for this: https://codecanyon.net/item/rentco-the-leading-booking-solution/24304341
Today we use Woocommerce booking, but what I see is that the booking plugin today is far too complicated for vendor customers. These customer are not so technical and too many options make things very difficult.
Best
Patrick - September 7, 2019 at 1:01 pm #80594
MemberOK, do you have this booking plugin?
If so, then please share with us at – wclovers.custom@gmail.com
We will take a look at it, whether this will work for multi-vendor sites or not!
If yes, then we will add it’s compatibility to WCFM.
- February 20, 2020 at 1:12 pm #107994
donnamackey83
ParticipantHello WCFM,
I am willing to add a search filter functionality for reservations to my store and I ‘ve already installed Woocommerce Bookings Plugin. For enabling search filter i ve found this Booking Filters and this will work as an addon to existing Woocommerce Bookings Plugin.
So, my questions is, would it compatibility with WCFM Plugins?
- February 25, 2020 at 12:52 pm #108673
Sure, you may use this. This does not require any special compatibility with multi-vendor setup.
You just have to filters using this.
