Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM – Marketplace (WooCommerce Multivendor Marketplace) › WooCommerce Car/Parts Filter Plugin
- This topic has 3 replies, 3 voices, and was last updated 5 years, 6 months ago by
criss.lyn2018.
- June 10, 2020 at 9:42 am #140129
hani
We are running e-commerce for auto parts, and filters such as Car make, model, year are a must in such sites.
We found the following plugin that we need your confirmation to proceed to install it. Any issues could come up?https://codecanyon.net/item/woocommerce-carparts-filter-plugin/6556524
Regards
- June 10, 2020 at 5:33 pm #140285
Avinaba
MemberHi, we need to check if this plugin is compatible with our multi-vendor solution. Infact, you can ask the plugin author if they have this compatibility.
- June 10, 2020 at 5:39 pm #140287
hani
ParticipantThis reply has been marked as private. - July 27, 2020 at 12:15 pm #156202
criss.lyn2018
ParticipantI don’t have much idea about this plugin as i have not used it. I also run a car auction site carzaamin(.)com using wordpress CMS. I have used a paid template for this purpose. In which all these functionality has been created. Because i normally prefer to use paid theme instead of plugin due to confliction with other plugins js libraries, but i only recommend this if your business is on beginner level. Anyways, eveyone has its own point of view and i have shared my own experience with you. Thanks
