Best Multi Vendor Marketplace Plugin for WordPress › Forums › WC Marketplace › WooCommerce Measurement Price Calculator
- This topic has 14 replies, 3 voices, and was last updated 6 years, 5 months ago by
- February 23, 2019 at 11:08 am #49688
Paul Sher
GuestHi – I see this is a new feature on WCFM. I have the WooCommerce Measurement Price Calculator plugin installed and can see the measurements tab on a product from the admin backend, but nothing from the frontend dashboard for admin or vendor. Is there some other setup I need to do?
- February 23, 2019 at 11:17 am #49690
Well, nothing required, just be sure your WCFM Ultimate plugin at latest version, 5.4.1
- February 23, 2019 at 11:35 am #49691
Paul Sher
GuestI think I have latest plugis Frontend Manager 5.4.1 and Frontend Manager Ultimate 5.2.0., but nothing showing on frontend dashboard for measurements
- February 23, 2019 at 12:34 pm #49697
– You have to update WCFM Ultimate to the latest version 5.4.1, this integration comes with Ultimate, not WCFM Free.
- February 23, 2019 at 7:17 pm #49753
Paul Sher
GuestI have Ultimate and 5.2.0 is the latest version (no update available). It is your Frontend Manager that has 5.4.1 as the latest version, which I also have.
- February 23, 2019 at 8:13 pm #49754
paul1
ParticipantI have had a look at your demo site – and measurements are also not showing up when I add a product.
- February 24, 2019 at 5:29 am #49759
Well, in demo we not yet installed Measurement plugin.
WCFM Ultimate latest version is 5.4.1, please re-activate your license once.
- February 24, 2019 at 9:01 am #49768
paul1
ParticipantI have tried de-activating and re-activating the licence. No change – version is 5.2.0 with no update available. I have also looked at my WCFM analytics plugin – and it seems same problem there – plugin indicates that it is up to date, but if I look at the changelog there are newer versions for the plugin. How to update?
- February 24, 2019 at 10:05 am #49775
paul1
ParticipantUpdate – I manually uploaded the new analytics plugin and over-wrote the existing plugin to update the analytics. As soon as this was done the Ultimate plugin was indicating that an update was available (?). So, I have been able to update the plugin and measurements option is now available on the frontend dashboard.
- February 24, 2019 at 10:13 am #49779
MemberDO you have any server side caching?
Or, are your using any plugin update checker plugin?
Then clear those and check.
Between, what is your registered email at wclovers.com
- February 24, 2019 at 10:27 am #49780
paul1
ParticipantThis reply has been marked as private. - February 24, 2019 at 11:32 am #49784
Well, license is perfect.
You are using this at multi-site installation, update notice not even at network admin site?
Is there any security or firewall type plugins?
- February 24, 2019 at 12:19 pm #49791
paul1
ParticipantThere was an update notice on network admin site for Ultimate, and this is how I became aware that the measurements feature had been added. I am not sure of what the version number was before updating, but after updating it was 5.2.0 and dashboard no longer showing update available. The message from the dashboard was the plugin was successfully updated. After manually updating the anayltics plugin, the Ultimate plugin on the network dashboard now showed that an update was available – so updated and now have version 5.4.0.
- February 24, 2019 at 12:20 pm #49792
paul1
ParticipantSorry – should be now have version 5.4.1
- February 24, 2019 at 12:57 pm #49800
MemberYeah, measurement integration comes at 5.4.1 version
- The topic ‘WooCommerce Measurement Price Calculator’ is closed to new replies.
