Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM – Ultimate › Woocommerce official dynamic pricing on product edit.
- This topic has 10 replies, 3 voices, and was last updated 7 years, 4 months ago by
Bingal.
- March 22, 2018 at 3:44 pm #20710
JJ
GuestI’m trying to use Woocommerce official dynamic pricing because it has a tab on the product editing page.
But I cannot find way to set this on WCFM not only at Wp-admin panel.
How Can I set this up?
- March 22, 2018 at 5:08 pm #20726
I am not getting your this line clearly – “not only at Wp-admin panel”?
Are you not getting this option is wp-admin -> Products -> Add Product ?
Then please go though the documentation once – https://docs.woocommerce.com/document/woocommerce-dynamic-pricing/?_ga=2.35237153.1645820854.1521738391-430337574.1495100302Thank You
- March 23, 2018 at 3:06 am #20751
JJ
GuestI mean I also like my Vendor can use the feature.
Not like the other dynamic pricing plugin, this one shows the option panel as a tab like attribute or shipping.
But I can not find them at front end manager’s product editing page.
- March 23, 2018 at 4:01 am #20752
MemberOK,I understand your requirement. WCFM not compatible directly with this plugin.
Let me check once is this can be setup using WCFM custom field or not!
- March 23, 2018 at 9:15 am #20765
JJ
GuestThanks!
So you mean you are going to check that for me right?
And what is WCFM custom field.
I dont find it at your addon.I checked the other plugin called Bulk Discount.
It works on WCFM but too simple plugin…Thanks
- March 23, 2018 at 10:26 am #20767
Yes, we are going to check this for you.
Here is WCFM custom field – https://wclovers.com/knowledgebase/wcfm-custom-fields/
- March 23, 2018 at 11:54 pm #20790
JJ
GuestHi
May I ask how long would this take?
Thank you so much
- March 24, 2018 at 10:05 pm #20836
Bingal
I will update you in 2-3 days on the same.
- March 29, 2018 at 11:52 pm #21077
JJ
GuestHi
Do you have any update about this?
Thank you very much for your support.
Best
- March 30, 2018 at 10:12 am #21092
Bingal
Our team is still looking into this.
I will update soon on this.
Thanks for your patience.
- April 2, 2018 at 5:29 pm #21205
Bingal
Our team has checked this plugin but it’s not possible to integrate using WCfM Custom field.
It requires custom coding to make this functional from WCfM product manager.Thank You
- The topic ‘Woocommerce official dynamic pricing on product edit.’ is closed to new replies.
