Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM – Ultimate › WooCommerce Subscriptions Gifting
- This topic has 2 replies, 2 voices, and was last updated 6 years, 5 months ago by
- January 27, 2019 at 5:04 pm #45472
Amy
I have WooCommerce Subscriptions Gifting active but after installing your plugin it is no longer showing. Is this a compatibility issue? I also note my Custom Product Tabs for WooCommerce has also been replaced with your default tabs.
Is it possible to have both of these plugins working with WCFM?
- January 27, 2019 at 8:44 pm #45481
Amy
GuestHi, after some research I believe I need your user’s ultimate additional module to take care of product tabs? I want to have set product tabs that the vendor must fill in for each product. These tabs are for things like ‘What’s inside’ ‘Overveiw’ etc.
Really need the product buy as a gift option. The wooCommerce extension I bought is not showing.
- January 28, 2019 at 5:54 am #45511
Well, WCFM compatible with WooCommerce Subscription and Custom products Tabs.
But for both these WCFM Ultimate require.
Well, for “WooCommerce Subscriptions Gifting” is any special setting require at individual product level?
As I know.not required. It’s just matter of global setting – https://docs.woocommerce.com/document/subscriptions-gifting/Thank you
- The topic ‘WooCommerce Subscriptions Gifting’ is closed to new replies.
