Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM – Marketplace (WooCommerce Multivendor Marketplace) › Wp 5.3: impossible to upload large images
- This topic has 5 replies, 2 voices, and was last updated 5 years, 9 months ago by
- November 27, 2019 at 1:48 pm #94242
fabricebartoli90
ParticipantHi guys!
After update my wordpress to the 5.3 version, wordpress avoid to upload images largen then 2500px.I tried to add this snippet to function.php to disable the scaling without success:
add_filter( ‘big_image_size_threshold’, ‘__return_false’ );
Somebody has the same problem?
- December 7, 2019 at 7:41 pm #96498
Please check what is your site’s Max Upload size – https://ibb.co/qJ2Qq6v
Check this at wp-admin -> WooCommerce -> Status
- December 7, 2019 at 10:38 pm #96538
fabricebartoli90
Participantupload size is 128mb, but images larger then 2500px are not uploaded in wordpress 5.2, is not a problem of size in Mb but is a problem of pixels
- December 9, 2019 at 1:26 pm #96703
MemberWell, WP does not have any rule to restrict images by pixels.
Please be sure, your theme does not have any such limitation. Talk to theme support once.
- December 9, 2019 at 3:02 pm #96739
fabricebartoli90
ParticipantAs a customer, I would advise you to listen to customer requests better, because you often give rash answers without first ascertaining what the customer is asking for. you can read herethat in the last wordpress update, wordpress makes this restriction, and the solution proposed in the link below does not work to disable this limitation in the wcfm dashboard.
- December 10, 2019 at 9:57 am #96826
MemberReally for the mis-undersatnding.
Do you have add this code in your site =
add_filter( 'big_image_size_threshold', '__return_false' );
Well, WCFM has no special file uploader, it uses WP default uploader.
- The topic ‘Wp 5.3: impossible to upload large images’ is closed to new replies.
