02Day 00Hr 44Min 28Sec
WP- Admin access, Social verification does not work
Best Multi Vendor Marketplace Plugin for WordPress Forums WC Marketplace WP- Admin access, Social verification does not work
Viewing 6 reply threads
    • #70467
      zoltan.b.feher
      Hi Team,
      I have serious issues, namely, the vendor can access the wp-admin dashboard with a quite wide manipulation range, even it is disabled by capability settings!!!!
      http://prntscr.com/o8uyk4
      Social verification does not work!
      Menu links are dead!
      https://www.loom.com/share/42eacc27b126479c984429e1da6757a3
    • #70922
      Do you have WCFM – Group & Staff addon?
      If so, then please be sure “WP Admin” access restricted for all groups capabilities as well.
      – Do you have setup Social verification from WCFM Admin Setting -> Verification ?
    • #71037
      zoltan.b.feher
      Yes I have G&S. I configured accordingly. Thanks!
      Yes, it is enabled. I figured out that all of the issues comes from WPML incompatibility. After I deactivated WPML all menu links, social verifications work well. Dead link, social verification. I have the latest WPML plugin. It worked well till the last WCFM update
    • #71134
      – It’s because of WPML mis-configuration, not incompatibility.
      Please share access details, I will fix this for you.
    • #71147
      zoltan.b.feher
    • #71295
      Thanks, but this site does not have WPML.
      Should I install this?
    • #71640
      zoltan.b.feher
      Hi Team,
      Issue resolved! Thank you for your help!
      Zoltan
  • The topic ‘WP- Admin access, Social verification does not work’ is closed to new replies.
