Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM – Marketplace (WooCommerce Multivendor Marketplace) › WPML RTL related
- This topic has 10 replies, 2 voices, and was last updated 8 years ago by
- September 12, 2018 at 6:07 am #31414
d-n-13
Here are some bugs & compatibility issues.
1- Store list doesn’t appear correctly in RTL : https://www.dropbox.com/s/gtuudi7k5o720n8/store%20list%20wpml.JPG?dl=0
2- (Please add Wizard WPML support) When registering in 2nd language RTL it will only show English Wizard : https://www.dropbox.com/s/lu2y2is0qnv5zgg/wizard%20wpml.JPG?dl=0
3- If vendor register in 2nd lang it will send him to Default LTR En Dashboard instead of 2nd lang RTL Ar
4- [This is not a big deal and only happens in wp-admin] wcfm links on top bar shows some links for En and some for Ar, issue doesn’t happen in frontend pages : https://www.dropbox.com/s/tromnicr5takuxm/wp-admin%20links.jpg?dl=0
I will do more testing, if I find something else related to WPML I will update you here.
- September 12, 2018 at 8:50 am #31443
1. Resolved in your demo site – https://www.4.wegospace.com/ar/stores-list/
2. (Please add Wizard WPML support) When registering in 2nd language RTL it will only show English Wizard : – We will check this
3- If vendor register in 2nd lang it will send him to Default LTR En Dashboard instead of 2nd lang RTL Ar – It’s related to point 2
4- [This is not a big deal and only happens in wp-admin] wcfm links on top bar shows some links for En and some for Ar – Just resolved in your demo site.
- September 12, 2018 at 9:34 am #31451
I have resolve 2 & 3 in your demo as well.
Kindly take a look.
- September 12, 2018 at 10:16 am #31460
d-n-13
You’re super fast!
it is 99% prefect, there is small issue in rating and badges in store list. Screenshot : https://www.dropbox.com/s/ktmpe3eisbso1w4/store%20list%20stars.JPG?dl=0
I tried to adjust float to right but it is still not perfect : https://www.dropbox.com/s/vvjgpk5wrgr3ttd/store%20list%20stars%202.JPG?dl=0
I’m going to test registration & wizard and i’ll get back to you if there is anything.
- September 12, 2018 at 1:55 pm #31488
1. it is 99% prefect, there is small issue in rating and badges in store list. Screenshot :
– This RTL CSS is required for the purpose, we will add this in next update. I have added in your site but due to caching it’s not working.
.store-data .star-rating > span, .store-ratings .star-rating > span{left:auto;right:0;}2. I tried to adjust float to right but it is still not perfect –
.bd_rating .star-rating, .bd_rating .wcfm_vendor_badges{float:right;margin-right: 0px;margin-left: 20px;}Thank You
- September 13, 2018 at 6:32 am #31545
d-n-13
* Resolved
* I translated the wizard and Registered new Ar vendor, it won’t show Translated Wizard. but after finishing the wizard it will send me to Ar Dashboard so that part is working.
* Resolved
* Resolved
Thank You.
- September 13, 2018 at 6:50 am #31548
d-n-13
ParticipantThis reply has been marked as private. - September 13, 2018 at 7:45 am #31555
Yeah, we are working on your demo site 🙂
Sorry for the inconveniences.
- September 14, 2018 at 12:04 pm #31632
d-n-13
Not at all, please take your time.
and please let me know if you find a solution.
- September 18, 2018 at 4:58 pm #31959
d-n-13
Any progress regarding the wizard ? if there is no easy solution then maybe we will have to disable wizard, I saw your wizard disabling code in another topic
Let me know if you have any progress or if I should disable the wizard.
Thank you.
- September 19, 2018 at 5:43 pm #32017
Resolved, please check in your demo 🙂
- The topic ‘WPML RTL related’ is closed to new replies.
