Forum Replies Created
Alaistair Jerrom-Smith
ParticipantOk, couple of amends that we’ve made to the code to get it a little more suitable for what we need.
When you select only delivery date to show you end up getting a time being displayed on the screen on the orders and order summary.
We amended as follows: (if delivery display format set to date then set current_time to midnight and work from there)
All in wp-content/plugins/wc-frontend-manager-delivery/core/class-wcfmd-delivery-time.php
In generate_vendor_delivery_time_checkout_field (around line 389)
if ($wcfm_delivery_time_display_format == 'date'){ //reset to midnight of today $current_time = strtotime('today midnight'); } else { $current_time = current_time( 'timestamp' ); }Then to make the time selection slightly nicer make them start on say 15 min blocks. Rather than 7:42am as an option have 7:45am instead..
Inbetween where $start_time and $end_time are first set in generate_vendor_delivery_time_checkout_field:
//lets start at a more reasonable time.. i.e. in the next 15 min block $datetime = new DateTime; $datetime->setTimestamp($start_time); $second = $datetime->format("s"); if($second > 0) $datetime->add(new DateInterval("PT".(60-$second)."S")); $minute = $datetime->format("i"); $minute = $minute % 15; if($minute != 0) { // Count difference $diff = 15 - $minute; // Add difference $datetime->add(new DateInterval("PT".$diff."M")); $start_time = $datetime->getTimestamp(); }finally change the section that sets $is_valid_time = true to be greater than or equal to etc.. rather than just greater than and less than:
Note its $next_time_slot >= $open_hours and $next_time_slot <= $close_hours that have just had the equals (=) sign adding in.. makes it work better for me.. especially if it’s delivery days that vendors are using (needs open time to be 00:00 and close time to be 23:59 in delivery times)if( ( $next_time_slot >= $open_hours ) && ( $next_time_slot <= $close_hours ) ) { $is_valid_time = true; break; }in wcfmd_customer_order_delivery_time_show, wcfmd_order_list_delivery_time_show, wcfmd_order_details_delivery_time_show
If date is midnight (i.e. it’s just display date) setting then don’t display time part..within the for each loop: (check if date time is midnight and if so then only show date)
$datetime = new DateTime; $datetime->setTimestamp($wcfmd_delvery_time); if( date_format($datetime,'H') == 0 && date_format($datetime,'i') == 0) { echo date_i18n( wc_date_format(), $wcfmd_delvery_time ); } else { echo date_i18n( wc_date_format() . ' ' . wc_time_format(), $wcfmd_delvery_time ); }Bit of a brain dump but hope it makes sense! (have also attached file)
