Forum Replies Created
id.manage
ParticipantUpdate: I changed a browser and found it finally works. Thank you. The colour of the arrow is a bit dim. Wish we could change the UI easily. Thanks again for your help!
id.manage
ParticipantProblem solved by clearing history. Thanks. I think it might be caused by the JS code I tested yesterday.
id.manage
ParticipantHi, I’ve tried but it doesn’t work. I even changed the font size, and also tried to use !important, but the font still looks that same. I wonder why?
id.manage
ParticipantThis reply has been marked as private.id.manage
ParticipantHi, the first part is perfect. I got my original UI back. Thank you so much. But I am having strouble to add JS code. I used Custome JS to add the code with condition of working only on this page as the post suggested, but my google map disappeared, and both distance mark and the number moved to the very left end of the slider.
id.manage
ParticipantHi Thank you for the quick reply. It’s probably not ultimate, but it should be from one of WCFM I updated yesterday. The UI changed immediaely after I updated them. And it’s the change on the page of [wcfm_stores] . Would you please let me know how can I change the style back?
id.manage
ParticipantThank you very much. The code doesn’t work but I have achived what I want by diactivate one of my plugins. I will see if I can find alternatives .
Thanks again
id.manage
ParticipantPerfect! You are a star!
id.manage
ParticipantThanks, I just did
id.manage
ParticipantI fixed it myself. Thanks
id.manage
ParticipantThis problem is solved. Thanks
id.manage
ParticipantIt works now. Thank you so much. You are a star!
id.manage
ParticipantThis reply has been marked as private.- AuthorPosts
