Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM – Ultimate › A few vendor dashboard related queries
- This topic has 13 replies, 2 voices, and was last updated 6 years ago by
- May 23, 2019 at 2:00 pm #63508
hello4
ParticipantHello there,
Could you kindly show me how to get these queries sorted?
1) How can I direct a vendor to vendor dashboard if they accidentally end up in the vendor registration page? I don’t want them to see the ‘You are not allowed to access this page…” message as it’s misleading.
2) How do I remove booking times from Bookings Lists? Or from every booking related screen within vendor dashboard.
3) How to check if it’s a logged in user is vendor or the store manager/admin?
4) How can we show all payment transactions (Show all) by default?
5) How can we show all payment transactions instead of limiting them to current month? If it’s not possible, how can we show the transactions for the last 3 or 6 months? By the way the placeholder text says: Choose data range. I believe it should be ‘date’ range.
6) How can we maintain a consistent date format within the dashboard? Some dates are shown as 2019-05-23, some are 23-05-2019 and some are May 23, 2019. How can we keep one format, ideally 2019-05-23 throughout the dashboard? This is the format currently set for WordPress default.
Thanks and regards,
- May 26, 2019 at 9:44 am #63828
hello4
Participant3 more to the list above:
7) How can we disable order emails to vendors? This is disabled on the dashboard but they keep receiving these emails. I only want them to receive booking related emails, not order notifications .
8) How can we edit to body text of WCFM emails?
9) How can we remove ‘Order’ statuses from vendor notifications?
- June 5, 2019 at 9:16 am #65968
hello4
ParticipantMay I have an update on this please?
- June 10, 2019 at 7:31 pm #66818
I am really sorry for delayed reply.
– You may use redirect plugin for this. Redirect “Store Vendor” user to “Store Manager” if they browse “Registration Page”
We can not add this in core plugin as “Membership Upgrade/Change” require this access.2) How do I remove booking times from Bookings Lists? Or from every booking related screen within vendor dashboard.
– Please use screen manager (at top bar right) to disable those fields for vendors – https://ibb.co/jDhHDsv
– WCFM has a function for this –
wcfm_is_vendor()
– Add this to your child theme’s functions.php –
add_filter( 'wcfm_payment_default_status_type', function( $default_status ) { return ''; });
– We will definitely fix typo error. But there is no way yet to change default listing date range!
– Where you have this date format “May 23, 2019”, please show me screenshot!
– You have to disable “Store New Order” from wp-admin -> WooCommerce -> Setting -> Emails
– You may edit Registration related emails from WCFM Membership setting panel.
Notification email contents are part of translation file.9) How can we remove ‘Order’ statuses from vendor notifications?
– DO you want to disable “Order Status” notification for vendors? Then you may do this from WCFM Admin Setting -> Notification Manager
- June 11, 2019 at 12:29 pm #66973
hello4
Thanks for the answers. I need further assistance though as some of those answers don’t work.
– I only want to remove the ‘time’ from the booking details, not the entire booking dates.5) How can we show all payment transactions instead of limiting them to current month? If it’s not possible, how can we show the transactions for the last 3 or 6 months? By the way the placeholder text says: Choose data range. I believe it should be ‘date’ range.
– Not even by changing the template file?7) How can we disable order emails to vendors? This is disabled on the dashboard but they keep receiving these emails. I only want them to receive booking related emails, not order notifications .
– This email is already disabled and all order related notifications are also disabled for vendorsIn addition to those, could you please tell me how to remove the two arrow head (>>) from Show All button?
Thanks and regards,
- June 14, 2019 at 5:13 am #67544
– I only want to remove the ‘time’ from the booking details, not the entire booking dates.– Hope you are dealing with only “All Day” bookings. We will add condition and remove time for “All Day” bookings. https://ibb.co/PZV4KLJ
– Not even by changing the template file?– We are checking this. Will add “filter” for this.
– Which emails they are receiving? Please go to WCFM Admin Setting -> Notification Manager -> Set OFF order related notifications for vendor.
– We will remove this in next update.
- July 20, 2019 at 11:30 am #73186
hello4
For some reason it’s not letting me to create new posts in here even after I logged into my account. Could you please check if MSG91 integration is still working after the latest updates as it doesn’t send SMS any more?
Best regards,
- July 21, 2019 at 9:02 am #73264
MemberPlease check at wp-admin -> WooCommerce -> Status -> Logs -> fatal_erros log -> is any error generated?
- July 21, 2019 at 3:50 pm #73321
hello4
ParticipantI can’t see any fatal errors relate to WCFM. These debug log is there though.
2019-07-20T10:57:08+00:00 DEBUG SMS:: : Txxxxd: You have received a Booking #4165 for Ted Baker floral peplum dress
2019-07-20T10:57:10+00:00 DEBUG SMS:: : Txxxxd: You have received a Booking #4165 for Ted Baker floral peplum dress
2019-07-20T11:06:28+00:00 DEBUG SMS:: : Txxxxd: You have received a Booking #4167 for Ted Baker floral peplum dress
2019-07-20T11:06:30+00:00 DEBUG SMS:: : Txxxxd: You have received a Booking #4167 for Ted Baker floral peplum dress
2019-07-20T11:11:17+00:00 DEBUG SMS:: : Txxxxd: You have received a Booking #4169 for Clutch Bag
2019-07-20T11:11:20+00:00 DEBUG SMS:: : Txxxxd: You have received a Booking #4169 for Clutch Bag
2019-07-20T11:24:31+00:00 DEBUG SMS:: : Txxxxd: You have received a Booking #4171 for White Dress
2019-07-20T11:24:32+00:00 DEBUG SMS:: : Txxxxd: You have received a Booking #4171 for White Dress - July 22, 2019 at 5:10 am #73388
Well, this log is coming that means SMS notification initiated and it triggered.
- July 22, 2019 at 7:54 am #73409
hello4
ParticipantI just tested it by removing all API details and it still gives the same log details:
2019-07-22T07:52:03+00:00 DEBUG SMS:: : Txxxxd: You have received a Booking #4176 for Clutch Bag 2019-07-22T07:52:03+00:00 DEBUG SMS:: : Txxxxd: You have received a Booking #4176 for Clutch Bag
Any thoughts?
- July 23, 2019 at 7:48 am #73543
MemberIs this sending other SMS? like, New order SMS to admin?
- July 26, 2019 at 2:40 pm #74024
hello4
ParticipantNo it doesn’t send any SMS at all.
- July 29, 2019 at 12:44 pm #74367
MemberWell, is there any template needs to be approve from MSG91 SMS account to send out those?
- The topic ‘A few vendor dashboard related queries’ is closed to new replies.
