Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM – Ultimate › About Commission payment time for vendors
- This topic has 3 replies, 2 voices, and was last updated 6 years, 11 months ago by
- August 10, 2018 at 6:34 am #28135
MOHO
ParticipantCurrent, when order status became processing and completed, Commission will give vendor, wait for “mark as paid”
could i change only completed order, Commission will give vendor?
because i want to wait the vendor mark products shipped, then change order status as “completed” give Commission, thanks.
wc-marketplace reply me:
@mohotw, we use the same hook to display the order in the vendor’s order page and create commission at the same time.
Hence, if you create the commission when the order status is complete, then the vendor will also see the order when the order status is completed.
So, you have to do some custom code for this. This support thread might be able to help you out :
– https://wc-marketplace.com/support-forum/search/wcmp_completed_commission_statuses/
– https://wc-marketplace.com/support-forum/topic/order-processing/I didn’t know this is your plugin control it or wc-marketplace plugin
I hope only when order became completed, then earning “N/A” have value, and add to total earnings at Reports menu.
By moho
- August 10, 2018 at 6:54 am #28139
For WC Marketplace commission only generated when a order status “processing” or “completed”, in simple word after order payment is done.
Do you want to exclude “processing” from this and want to allow only completed for withdrawal?
Between, how your commission is sending out to vendors? By withdrawal request or automatic disbursal?
- August 10, 2018 at 7:09 am #28141
MOHO
ParticipantI have a question
if want to exclude “processing” from this and want to allow only completed for “total earnings”
i change product commission, when order processing.
then i completed order, the order display earning value and add to “total earnings”
this value will be the new commission i type?Between, how your commission is sending out to vendors? By withdrawal request or automatic disbursal?
I will create our payment form by formidable pro(https://formidableforms.com/), and give money with our local bank. - August 10, 2018 at 7:49 am #28149
MemberOK, i understand .
I am checking this how can be altered!
- The topic ‘About Commission payment time for vendors’ is closed to new replies.
