01Day 08Hr 58Min 19Sec
About manage vendor product
Viewing 3 reply threads
    • #27593
      MOHO
      Thanks you give my code to limit vendor can’t edit the price of live product.
      I have another idea
      1. if i let vendors edit price field, but once the vendor edit price, then became the status of product to “awaiting approval”, and notice admin.
      2. another way is if the vendor edit any field of the product, then submit, became the status of product to “awaiting approval”, and notice admin.
      Could make this?
      If could, i will think about use which way to manage vendor’s products, thanks.
      By moho
    • #27610
      You can definitely do this, check this capability option – https://ibb.co/mq6DJz
      If you set this OFF, then if vendor edit and save any publish product it will again waiting for Admin approval.
      You may try this!
    • #27616
      MOHO
      Great option, i will use it, thanks.
    • #27704
      Great, you are welcome 🙂
  • The topic ‘About manage vendor product’ is closed to new replies.
