Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM – Feature Request › ACF Features missing compatibility
- This topic has 3 replies, 3 voices, and was last updated 7 years, 5 months ago by
- February 25, 2019 at 2:41 am #49893
acauaferreira
ParticipantHi friends, more than 3 months after this topic below, i saw some minor new features integrated with Wcfm in your changelogs, but none of that said below
https://wclovers.com/forums/topic/are-acf-pro-5-7-7-compatible-its-missing-a-lot-of-settings/The possibility to full use ACF was the main decision to use WCFMU
Inside Edit group field, almost all the fields settings did not works inside wcfm, if I access from wp-admin works as it should.
TOP BUGS:
1-Add new choice for checkbox (Allow ‘custom’ values to be added)
2-Conditional logic , Character Limit, append,Preppend,Layout Horizontal - February 25, 2019 at 9:03 am #49970
“Inside Edit group field, almost all the fields settings did not works inside wcfm”
– That’s right. ACF no way support it’s setup from Frontend. SO we have to implement all these custom for frontend.
Now, creating a total new ACF from frontend will take a lots of time.We are working on this. Right now, we are trying to make it’s conditional logic work for front-end fields!
- February 25, 2019 at 9:52 am #49989
Shop manager
GuestHow can I set different custom field for different types of category in front end dashboard
- February 26, 2019 at 4:50 am #50085
MemberThis is possible using ACF Pro, you have setup custom fields group rule by “Product Category”.
- The topic ‘ACF Features missing compatibility’ is closed to new replies.
