Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM – Ultimate › ACF for other post types
Tagged: ACF, Bookable Resources, WooCommerce bookings
- This topic has 7 replies, 2 voices, and was last updated 6 years, 8 months ago by
- August 23, 2019 at 7:56 pm #78054
Mitchell Gould
ParticipantI have been using ACF to add custom fields for my WooCommerce Bookings bookable resource post type. If I edit a resource from wp-admin, it works fine, but the field group is not available in WCFM Ultimate.
Is there an easy way to accommodate this?
- August 28, 2019 at 5:14 pm #78800
You may add custom field for resource post type.
But are you able to make those functional?
Only add some field and save those is not enough, i guess!
- August 30, 2019 at 2:08 pm #79238
Mitchell Gould
Participant@Keymaster: But are you able to make those functional?
Yes – they are functional in wp-admin, but I can see in wcfm that the views for bookable_resources are custom to wcfm.I’m pursuing an alternate approach. My fields are now in a custom post type. I’m trying to use the wcfm-custom-menu plugin, but its not working properly. All end-points from the demo end in a 404 error rather than loading the views in the dashboard. I have another thread about it.
- September 2, 2019 at 12:33 pm #79609
– You do not understand my query!
I mean to say, are those fields has any effect on Booking Resource?
- September 2, 2019 at 2:44 pm #79653
Mitchell Gould
ParticipantThey have no effect on how woocommerce deals with booking resources. They are used elsewhere. I’ve changed my approach and am now using a custom post type, taxonomies and meta-boxes to capture the data and then associating it with a resource id and vendor id.
- September 2, 2019 at 2:44 pm #79655
Mitchell Gould
ParticipantBy the way, does WCFM-ultimate assign a vendor ID to a resource created by a vendor?
- September 4, 2019 at 7:52 am #79943
– Yeah off course.
- September 4, 2019 at 7:52 am #79944
MemberWell, I am not very sure what is purpose.
But I think you may do this using WC Product Addons – https://woocommerce.com/products/product-add-ons/
- The topic ‘ACF for other post types’ is closed to new replies.
