Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM › Add Images to long description easily
- This topic has 5 replies, 2 voices, and was last updated 7 years, 3 months ago by
- April 21, 2018 at 2:59 pm #22166
gusslou
ParticipantHi, great plugin.
1. I would want to know though. Is there a way to add images to the long and short description easily? I mean by clicking on the add image or media link which would open the media gallery so the user can select images from the pool there.2. If I copy the link of an image from another website and paste that image link into the image source form input (for long and short description), what happens behind the scenes. Is the image copied to my woocommerce media gallery or not? Trying to figure out if images would start disappearing from my woocommerce site because i copied the link from another website (in case the website removes that image for some reason).
- April 22, 2018 at 7:02 am #22175
Right now it’s not possible to upload images/media directly into description/excerpt editor, only links are allowed.
When you are using a image link it’s not copied to this server, image serves from that third party server, but you may bypass this and upload image to this server from media popup at featured/gallery image and use link from there.
- April 24, 2018 at 12:41 am #22262
gusslou
ParticipantHmmm….I was wondering though, is it something that can be done easily. I mean could you provide a code snippet that would add that feature to the current interface? Would really appreciate it. Really love WCFM but that bit is a real issue. We usually prefer to some more images in the long description area and it would really help if the process was much simpler like in the wordpress backend.
- April 26, 2018 at 8:24 pm #22410
gusslou
ParticipantThis reply has been marked as private. - April 27, 2018 at 8:24 am #22423
We will look in to this and will try to add this feature as well.
It’s not possible to achieve just by adding a small code snippet.
- May 8, 2018 at 11:01 pm #23019
MemberNow you can do this easily as WCfM 4.0.8 uses WP default editor in front-end as well.
- The topic ‘Add Images to long description easily’ is closed to new replies.
