Best Multi Vendor Marketplace Plugin for WordPress › Forums › WC Marketplace › Add manual commission
- This topic has 6 replies, 2 voices, and was last updated 7 years, 2 months ago by
- September 15, 2019 at 9:08 pm #81833
vladte4
ParticipantI would like to add a commission manually after the approval of the goods (Manually charge money), and not automatically. It would be convenient for me, since I have my own approach to each seller. Please add this feature. Or how can I do this? I really, really wanted to see such functionality.
- September 17, 2019 at 10:28 pm #82192
I am not getting this very clearly.
Do you want to add commission manually after order placed?
Why so! You may set different commission for different vendors. Even you may set commission for individual products as well!
- September 17, 2019 at 11:34 pm #82200
vladte4
ParticipantYes, I want to add commission manually after order placed. And more precisely, if possible, add the manually commission after a successful order.
I was looking for a plugin to dropshipping, your plugin suits me the most, but does not have this function. If you add this, it will be a universal plugin that can be used for everything. I would really appreciate it if such a feature appears.
Thank you very much!
- September 19, 2019 at 5:43 pm #82471
– Well, direct commission edit is not allowed. You may edit/update order items, commission will be updated automatically.
– We have this in plan, will add very soon.
- September 19, 2019 at 5:45 pm #82472
MemberWhy you are not using this Drpshipping plugin ? https://docs.woocommerce.com/document/woocommerce-dropshipping/
- September 23, 2019 at 11:32 pm #83245
vladte4
ParticipantI really like your admin panel design. And there are so many useful features.
Photo – I suggest here to add a button to change. To be able to add in case of successful order or subtract amount in case of refusal.
I will be very grateful if such a feature appears in the next updates. I will very much wait. Thank you!
And to whom can I write an error with the Elementor plugin on my site?
You must be logged in to view attached files. - September 25, 2019 at 8:40 pm #83585
– Sure, we will add this option soon.And to whom can I write an error with the Elementor plugin on my site?
– Please contact Elementor support for this. You may also talk to your theme support.Thank You
- The topic ‘Add manual commission’ is closed to new replies.
