Add Marketplace Split Cart Plugin for WooCommerce compatibility
Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM – Feature Request › Add Marketplace Split Cart Plugin for WooCommerce compatibility
Viewing 3 reply threads
    • #86344
      aemr45
      Hi, I need to allow coustumers buy from one vendor at a time and this plug in “Marketplace Split Cart Plugin for WooCommerce” has what I need but it says its only for Multi Vendor Marketplace Plugin for WooCommerce.
      I haven’t found the way to do this with WCFM Marketplace, can you help me adding compatibility with plug in Marketplace Split Cart Plugin for WooCommerce?
    • #86762
      – So, you want restrict customers purchase from one vendor in one order, right?
      Well, no plugin require for this, just add this code to your site – https://docs.wclovers.com/tweaks/#single-vendor-checkout
    • #87037
      aemr45
      Ok, this will work, but can I make the notice message last longer, and it would be great if I could send to the wishlist, the articles that could not enter the cart
    • #87314
      aemr45
      The notice message is not showing when the button “Add to cart” is clicked from the Compare table and from the Wishlist, it would be great to find a way to fix this.
      I already figured out how to add more time to message, Woocommerce > General Catalog > Cart Notification Auto Hide
  • The topic ‘Add Marketplace Split Cart Plugin for WooCommerce compatibility’ is closed to new replies.
