Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM – Membership › Add Membership "Submit" is not working
- This topic has 8 replies, 2 voices, and was last updated 7 years, 11 months ago by
- December 6, 2018 at 11:27 am #39170
Rohan Sharma
GuestHi
i am trying to add membership with Add button and when i am trying to Save this it is not showing any membership after page reload. please help - December 6, 2018 at 11:39 am #39175
I think you have JavaScript error in page so membership is not properly saving.
Can you please check this in Google Browser console?
- December 6, 2018 at 11:59 am #39182
Rohan
GuestUncaught Error: Option ‘ajax’ is not allowed for Select2 when attached to a <select> element.
at String.<anonymous> (helper.js?ver=4.9.8:35)
at Function.each (jquery.js?ver=1.12.4:2)
at d.prepareOpts (helper.js?ver=4.9.8:35)
at d.prepareOpts (helper.js?ver=4.9.8:36)
at d.init (helper.js?ver=4.9.8:35)
at HTMLSelectElement.<anonymous> (helper.js?ver=4.9.8:37)
at a.fn.init.each (jquery.js?ver=1.12.4:2)
at a.fn.init.a.fn.select2 (helper.js?ver=4.9.8:37)
at HTMLDocument.<anonymous> (wcfmvm-script-memberships-manage.js?ver=2.2.5:44) - December 6, 2018 at 12:00 pm #39183
Rohan
GuestThis error i can see on Google Console.. i just notice that settings Save is also not working.
- December 6, 2018 at 12:04 pm #39185
“Option ‘ajax’ is not allowed for Select2”
– that’s the main reason. WCFM will not work with this.
There has something in your site which loading a very old version of “select2” library so this error is there.
Possibly your theme doing this, kindly check this with activating default WP theme.
- December 6, 2018 at 12:14 pm #39189
Rohan Sharma
Guesti am using the theme “Colosseum”
https://themeforest.net/item/colosseum-hotel-premium-hotel-resort-wordpress-theme/20541555
i cannot change the theme. is there any possible suggestion or setting i can make so i can use this, please?
Hoping for some positive reply from your end!
- December 6, 2018 at 12:52 pm #39198
I am not asking you to change the theme.
But we have to find out from where this old “Select 2” library loading.
So, I asked you to check once by activating any WP default theme.
May be it’s loaded by some plugin!
Well, can you know me your site URL, I think i can check that from outside.
- December 6, 2018 at 12:56 pm #39201
Rohan Sharma
GuestHere it is the URL —
- December 6, 2018 at 2:18 pm #39203
It’s your theme which loading a 4 years old select 2 library -> https://aladinforrich.com/wp-content/themes/colosseum/assets/js/helper.js?ver=4.9.8
Here is version -> https://ibb.co/S0vWD1G
Please contact that theme author and ask them to update this.
- The topic ‘Add Membership "Submit" is not working’ is closed to new replies.
