Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM – Product HUB › 'ADD NEW PRODUCT' NOT WORKING
- This topic has 6 replies, 3 voices, and was last updated 6 years, 3 months ago by
- December 10, 2019 at 1:58 am #96786
admin-6154
When a vendor is logged into their account, the ‘add new product’ function isn’t working.
Also, vendors are unable to login to their accounts when ‘recaptcha’ is used – the login button is overlaid by the recaptcha. - December 12, 2019 at 9:05 am #97158
Kindly show me screenshot for this.
Between, login form is not form WCFM. It’s your theme CSS issue, please contact theme support for this.
- December 12, 2019 at 10:45 pm #97289
admin-6154
ParticipantThere’s nothing to show you – all that happens is that when you try and add a new product, all the fields can be filled in but it won’t ‘save’.
- December 12, 2019 at 11:28 pm #97300
admin-6154
ParticipantThis is a screenshot of the login page accessed from the ‘Store Manager’ link. Login button replaced with recaptcha.
You must be logged in to view attached files. - December 20, 2019 at 5:58 pm #98217
KeymasterWhich theme are you using? Also, the product save is done via ajax. That means, if there is a JS error on the site, it will not work. Could you please check if there is any JavaScript error happening to the site from your Google Chrome Browser console (What is browser console – https://support.airtable.com/hc/en-us/articles/232313848-How-to-open-the-developer-console)
- December 22, 2019 at 6:17 pm #98493
admin-6154
ParticipantTheme is DIRECTORY+ by Ait-themes.com
Please see attached screenshot.Attachments:
You must be logged in to view attached files. - December 23, 2019 at 10:35 am #98627
MemberWell, as I see your site using a very old version of “select2” library. may be it’s by your theme or some other plugin.
If you are not able to find out this then may contact us here – https://wclovers.com/woocommerce-multivendor-customization/
We will debug this for you.Thank you
- The topic ‘'ADD NEW PRODUCT' NOT WORKING’ is closed to new replies.
