Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM – Feature Request › add openstreetmap.org as option please!!!
- This topic has 17 replies, 7 voices, and was last updated 5 years, 6 months ago by
- October 18, 2019 at 1:28 am #87456
HMS
i guess a lot more people would buy and love your script, if you also would support openstreetmap.org
I guess the API is extreme simple, nearly the same as google-maps – so easy for you to offerBUT from the customer point of view…. openstreetmap.org is FREE,…
google-maps costs A LOT of money when you get some traffic to your site.IF any other customer reads this posting and you would like to have this feature too,
just reply to this posting. Thanks! - October 18, 2019 at 3:43 pm #87575
kaloomee
ParticipantAn alternative to Google maps would be a great move
It can also be rather time consuming and sometimes nearly impossible, for a new Google user to create a google maps account
The amount of information that they now require is okay if you are an established business but for start ups, the info that Google ask of you is not available.
I am having problems setting up my Google maps account so an alternative would greatly help me. - October 18, 2019 at 3:58 pm #87579
sdel_nevo
ParticipantThat would be brilliant
the cost of using google can very quickly mount upusing openstreetmaps instead would eb a fantastic addition
Steve
- October 23, 2019 at 9:44 am #88363
aemr45
ParticipantPlease add openstreetmaps support, it would be very helpful.
Thank you for the great job!
- October 23, 2019 at 3:26 pm #88584
MemberWe are working on this, will be there very soon.
Thanks for your patience.
- November 22, 2019 at 3:44 am #93352
sdel_nevo
ParticipantHi Guys
I’m just wondering how this is coming on, will this be something that’s going to be added in the next few updates?
I would love this as it would lower our costsor would it be best that we request this as a custom project
Steve - November 23, 2019 at 12:12 pm #93595
We will add this in WCFM core very soon, have plan to add this within end of this year.
- November 23, 2019 at 3:32 pm #93616
sdel_nevo
ParticipantHi guys
That’s great news, many thanks
Will this have the same functionality as google maps,
Clicking the vendors address on their store page
Vendors shown on store location mapIf that’s the case could the vendors location be taken from the store address this will remove one more item that needs to be filled out when vendors sign up
Steve
- November 26, 2019 at 2:55 pm #94031
MemberYeah, all map functionalities will be same as now.
- November 26, 2019 at 3:01 pm #94032
sdel_nevo
that’s going to be fantastic 🙂
Steve
- January 13, 2020 at 2:04 pm #101871
CommunityCorals
ParticipantHello, is there any update in regards to timeline? I can´t longer afford paying google as I have like 100K API calls a month.
If it still takes time to move to openstreet – Is there no chance to exclude API call from product page? I do not use any map or anything on product but still issue a API call which is driving cost.
Need a quick solution as like I mentioned cost are not bearable anymore 🙁
BR
Dominique - January 13, 2020 at 10:49 pm #101934
aemr45
ParticipantHi there, they just add Open Street Map support in last update! I haven’t test it out yet, but I’m happy is here now, hope this info works for you.
- January 14, 2020 at 1:02 pm #101993
CommunityCorals
ParticipantHi, thanks for the info. I updaten and choose street map option. The address field does not pull any location data though. So radius search doesn´t seem to work?
Is there any documentation?
Dominique - January 14, 2020 at 3:30 pm #102012
Paulette
ParticipantHi, I now have a map showing on my sellers listing page (which was not here yesterday) whereas I didn’t change anything on my settings…
The issue is that the map is always showing Egypt whereas all my stores are in Asia. And it’s NOT showing any of my stores…
Also, I would like the map to be in English (currently, it shows each country in its own alphabet so Egypt in Arabic, China in Chinese and so on).> Where can I manage / enable / disable this new map module?
- January 15, 2020 at 1:53 pm #102112
CommunityCorals
ParticipantAnyone tested openstreetmaps for geolocation? As mentioned it doesnt work for me 🙁
- January 22, 2020 at 5:32 am #103115
aemr45
ParticipantI just figure out that you need to set the location for each vendor in the vendor manager, on admin’s dashboard.
Under store settings you will find store location. When you set it up, the map will work correctly, It is not so accurate but I imagine that being an open source map, we need to contribute to its database.
- January 31, 2020 at 2:20 pm #104786
Paulette
ParticipantAfter asking WCLovers support for my problem, they updated the plugin and now my map is working: I can set the location I wish the map to show. But the map is still not in English, but in all countries’ alphabet which is making it difficult to read in Asia. Anyone know how I can set the map’s language?
Also, as a vendor, I have set my location properly but it still doesn’t appear on the map. So following aemr45 advice, I manually added it as Admin this time and it’s now showing on the map. But I find it strange that admin has to manually add the stores’ locations even when vendors already set their address in their dashboard. It would be nice if this could be displayed automatically on the map whenever vendors add their location.
- February 6, 2020 at 11:36 am #105686
MemberWell, as Map library and integration codes are changed so you have to clear your site caches.
If not cleared then it will not work properly.Also check in Google Chrome Browser console, is there any JavaScript error happening to the site or not!
(What is browser console – https://support.airtable.com/hc/en-us/articles/232313848-How-to-open-the-developer-console)
- The topic ‘add openstreetmap.org as option please!!!’ is closed to new replies.
