Best Multi Vendor Marketplace Plugin for WordPress › Forums › WC Vendors › Add 'Paid Members Subscriptions' Content restriction module to vendors Dashboard
- This topic has 12 replies, 2 voices, and was last updated 7 years, 1 month ago by
- February 14, 2019 at 10:37 am #48156
Matt
GuestHi.
Love the plugin (using free version currently) but would like some assistance in implementing some adjustments.
I am running WC Vendors and Woocommerce plus Paid Members Subscriptions (PMS).
In the standard woocommerce add product there is a box from PMS where vendors can tick boxes to disable access to certain members. How can I add this module/box to the WCFM Dashboard when adding a new product? Or add a global content restriction to products on the site for non-members…Also, I have code in functions.php which pre-populates the long description form with text as a guide to the vendor when creating product text format. How can I add this pre-populated text to the WCFM add product page?
thanks!
- February 14, 2019 at 10:43 am #48160
Are you using this plugin ? https://wordpress.org/plugins/paid-member-subscriptions/
*** Not getting this clearly. Where you want to add this? Why you are not WCFM Knowledge Base for the purporse.
- February 14, 2019 at 11:35 am #48180
Matt
Guestthanks for the quick reply. yes that is the correct plugin.
I want to add text to the Long Description (add Product) so vendors have a guide of how to fill out this description box.
thank you!
- February 14, 2019 at 1:15 pm #48202
“I want to add text to the Long Description (add Product) so vendors have a guide of how to fill out this description box.”
*** OK, so you want to pre-fill description field. Can you please show me screenshot of existing code at functions.php
- February 14, 2019 at 10:59 pm #48292
Matt
GuestAlso, text boxes in store manager keep displaying white text so it cannot be seen. I want it to be the default black text.
I added this code to functions.php which corrected the issue in add product, but knowledgebase is still showing white text/white background in the ‘details’ box.add_filter( ‘wcfm_is_allow_rich_editor’, function() {
return false;
}, 750 );add_filter( ‘wcfm_editor_newline_generators’, function() {
return [“</p>”];
}, 750 ); - February 14, 2019 at 11:01 pm #48293
Matt
Guestthis is my code in functions.php to pre-fill into product long description;
//Custom Product data template
add_filter( ‘default_content’, ‘my_editor_content’ );
function my_editor_content( $content ) {
$content = “Item:_____________
Good to know:_____________
Loan terms (if applicable):_____________
GIFT/SWAP/TRADE:return $content;
//end custom Product data template - February 15, 2019 at 4:29 am #48321
I added this code to functions.php which corrected the issue in add product, but knowledgebase is still showing white text/white background in the ‘details’ box.**** Please do not add such code for this. Show me screenshot for this. Or, it will be best if you can give me a test vendor account.
It’s CSS issue due to theme or some other plugin!Thank You
- February 15, 2019 at 7:09 am #48362
Matt
GuestOK. what about the pre-fill product description, can this be done?
- February 15, 2019 at 7:17 am #48365
Please use this code –
add_filter( 'wcfm_product_manage_fields_content', function( $content_fields, $product_id, $product_type ) { if( isset( $content_fields['description'] ) && !$product_id ) { $content_fields['description']['value'] = 'Item: _____________ Good to know: _____________ Loan terms (if applicable): _____________ GIFT/SWAP/TRADE:'; } return $content_fields; }, 50, 3 );Thank you
- February 15, 2019 at 8:34 am #48392
Matt
GuestThats awesome, thank you for the code!
Just 2 more requests please…
The Description box – how can I make it start at the same size as the short description box so we can see more of the pre-fill text? ( i know you can drag the box down but wanting to make life easier for vendors). And can the Download checkbox not be visible?
Going back to my first question… can i get the PMS module (to restrict product views to logged in members) into the Add Product screen?
Thanks ( i cant see a way to add screenshots to this message)
- February 16, 2019 at 1:25 pm #48522
**** DO you want to make description box small in height?
You may disable “Downloadable” from Capability for vendors.Going back to my first question… can i get the PMS module (to restrict product views to logged in members) into the Add Product screen?
*** We are checking this
- February 16, 2019 at 10:08 pm #48565
Matt
GuestThis reply has been marked as private. - February 18, 2019 at 6:05 am #48693
WC Vendors capability will not work for WCFM dashboard. Don’t you have this option under WCFM Capability?
Are you using WCFM Free only?For custom plugin integration please contact here – https://wclovers.com/woocommerce-multivendor-customization/
It will be a custom development.Thank You
- The topic ‘Add 'Paid Members Subscriptions' Content restriction module to vendors Dashboard’ is closed to new replies.
