Add product form homepage dashboard
Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM › Add product form homepage dashboard
Viewing 5 reply threads
    • #108936
      Grégoire Tabeau
      Hi there,
      Thanks for your plugin.
      Is it possible to put the add product form on the homepage dashboard ? Otherwise, disabling the add product floating button and make a real one on the menu ? Thank you in advance.
      Have a nice day.
    • #109846
      – You may disable this product popup module form WCFM Admin Setting -> Modules -> Set OFF Popup Add Product
      You may add store manager dashboard “Add Product” page url anywhere in your site.
    • #110696
      Grégoire Tabeau
      Thank you for your answer. Unfortunately, i’m affraid this is not answering to my question. Please find attached the part i would like to change. Change the menu item “products” and submenu item “add new” to two menu separate item menu. Is it possible ? Thank you in advance.
    • #110941
      add_filter( 'wcfm_add_new_product_sub_menu','__return_false');
      And add new menu in admin dashboard->settings->Menu manager (PFA)
    • #110996
      Grégoire Tabeau
      Thank you it’s perfect. Add to this, I have a last issue. Category wise is not working well. I always have 4 basics attributes. New attributes selected are not display. Thank you for your help.
    • #111145
      You are always welcome 🙂
      For another issue, please explain little more. We didn’t get you And kindly create another topic for this.
  • The topic ‘Add product form homepage dashboard’ is closed to new replies.
