Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM › Adding Fixed Price above and below amount threshold
- This topic has 5 replies, 3 voices, and was last updated 6 years, 5 months ago by
- March 12, 2019 at 9:46 am #52237
neelesh.pednekar
Currently, in the settings for vendor commissions, I can set a percentage and fixed commission for vendors.
However, I would like to know how to set the commission to percentage and set the fixed price based on the price of the products. For example, any products below Rs 1000 will attract Rs 20 as closure fees and above will attract Rs 40.
Looking forward.
- March 12, 2019 at 2:45 pm #52285
Well, you may off course setup commission “By Product Price” rule – https://ibb.co/1z27bG8
- March 12, 2019 at 2:51 pm #52286
neelesh.pednekar
Appreciate your prompt revert.
We are looking to use a fixed commission in conjuncture with “By Product Price” feature.
Kindly advice.
Thanks and Regards,
Neel - March 12, 2019 at 4:44 pm #52311
Sorry, may be I am not getting your concept!
Fixed Commission option is there for “By Product Price” – https://ibb.co/7zKmWcz
- March 12, 2019 at 4:56 pm #52313
Neelesh
I would like to charge a percentage per category and then I would like to charge per sale.
For example, the shop will charge 15% on each category. Apart from the percentage, every order will be charged as sales fees. This fees need to vary depending on the product price.
- March 13, 2019 at 4:50 am #52373
– Well, you are allowed to setup commission at levels –
1. Vendor
2. Category
3. ProductNow, this is not possible to work commission rule depending upon two dependencies. If you want to charge different commission for different product price then you have to set commission for each product or set commission by “Product Price”.
- The topic ‘Adding Fixed Price above and below amount threshold’ is closed to new replies.
