Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM – Marketplace (WooCommerce Multivendor Marketplace) › Additionnal field
- This topic has 3 replies, 2 voices, and was last updated 5 years, 10 months ago by
Sarmistha Chakraborty.
- May 3, 2020 at 4:26 am #125869
aurelien_boutillier
My website is an art site.
I would like to offer the possibility for the vendors to fill in the name of the artist on the add product form and display it on the product page such as the attributes or the dimensions of the painting. I can’t add a free field in attributes settings.Is it possible ? Do you have any idea to do that ?
Aurélien. - May 4, 2020 at 12:13 pm #126342
You can achieve this with our “Product Custom Field” feature option. WCFM-dashboard -> Settings -> Product Custom Field.
https://wclovers.com/wp-content/uploads/2017/09/wcfm_custom_fields_visibility_options.png
https://wclovers.com/wp-content/uploads/2017/09/featured_image_field_setup.pngThanks.
- May 4, 2020 at 7:22 pm #126536
aurelien_boutillier
Thanks, I activate the product custom field and I try to add a custom field.
But I have an issue.
The field “visibility” doesn’t work. In the dropdown list I have only “Do not show”. The other possibilities such as “with product summary” are not displayed.
Have a look at the screenshot.Do you have any idea to solve this problem ?
Aurélien.Attachments:
You must be logged in to view attached files. - May 4, 2020 at 7:55 pm #126556
For this options will require our premium WCFM-Ultimate plugin.https://wclovers.com/product/woocommerce-frontend-manager-ultimate/
