Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM – Ultimate › Affiliate addon – Commission from admin
Tagged: Affiliate Commission, affiliation bug, affiliation problem, commission bug, Commission from admin
- This topic has 3 replies, 2 voices, and was last updated 5 years, 10 months ago by
- September 29, 2019 at 3:26 am #84327
aghorbany
ParticipantHello
Thank you for your hard work!I like to know is it possible to add an option to affiliate addon to calculate affiliate Commission from the admin Commission. I think this will fix many problems for many kinds of Commission calculation for everyone.
Let’s say we have many kinds of products or services categories and we need to set a different kind of admin commission for each seller differently and separately and in the same time we have different affiliate users with different affiliate commissions.The only way to do simple affiliate commission calculations and advance calculations is if give a possibility to set affiliate Commission from the admin Commission.
seller commission:85%
admin commission:15%
affiliate commission:10% from admin
Product cost : 100$
for seller:85$
For admin : 15$ – 10% = 13.5$
for affiliate user: 1.5$This kind of calculation helps admin to get more flexibility and wide range of options to set commissions for sellers and affiliate users at the same time.
Please add this option. If not help me manually to do it for my self.
Best regards
- September 30, 2019 at 3:30 pm #84521
Sorry, this is not supported right now!
Either Affiliate commission will be calculated on total item cost or on vendor commission.
When it will be calculated on item cost Admin has to pay this, it’s not deducted from vendor’s commission.
- October 1, 2019 at 10:01 am #84604
aghorbany
ParticipantThis method that the plugin use for commission calculating from admin is not flexible and so limited.
for example, if you have vendors with different commission and affiliate users also with different commission the plugin can not help at all.
It’s an important part for marketing and sales. I like to add an option like this. How can i do that?Thank you
- October 10, 2019 at 9:37 pm #86093
– It’s already there, You may setup commission for each vendor and affiliate.
- The topic ‘Affiliate addon – Commission from admin’ is closed to new replies.
