Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM – Ultimate › Ajax error : No Orders showing
- This topic has 12 replies, 2 voices, and was last updated 7 years, 1 month ago by
- July 11, 2018 at 9:29 am #26272
Vinz
ParticipantHi WCLOVERS!
I have a big problem : Orders are not showing on WCFM U when my Vendors want to manage them ! But it works with Admin…! I use WC VENDORS 2 plugin and the problem still here if I try with WC MARKETPLACE plugin.A pop-up appears with the error message :
DataTables warning: table id=wcfm-orders – Ajax error. For more information about this error, please see http://datatables.net/tn/7And the WC logs are :
2018-07-11T11:00:41+00:00 CRITICAL Uncaught Error: Class ‘WCV_Orders’ not found in /home/MY-DOMAIN-NAME/www/wp-content/plugins/wc-frontend-manager/controllers/orders/wcfm-controller-wcvendors-orders.php:212
Stack trace:
#0 /home/MY-DOMAIN-NAME/www/wp-content/plugins/wc-frontend-manager/controllers/orders/wcfm-controller-wcvendors-orders.php(21): WCFM_Orders_WCVendors_Controller->processing()
#1 /home/MY-DOMAIN-NAME/www/wp-content/plugins/wc-frontend-manager/core/class-wcfm-ajax.php(123): WCFM_Orders_WCVendors_Controller->__construct()
#2 /home/MY-DOMAIN-NAME/www/wp-includes/class-wp-hook.php(286): WCFM_Ajax->wcfm_ajax_controller(”)
#3 /home/MY-DOMAIN-NAME/www/wp-includes/class-wp-hook.php(310): WP_Hook->apply_filters(”, Array)
#4 /home/MY-DOMAIN-NAME/www/wp-includes/plugin.php(453): WP_Hook->do_action(Array)
#5 /home/MY-DOMAIN-NAME/www/wp-admin/admin-ajax.php(99): do_action(‘wp_ajax_wcfm_aj…’)
#6 {main}
thrownWhat’s going on ???
Thanks !!
- July 11, 2018 at 10:06 am #26273
I am really sorry for the inconveniences but this issue comes from WC Vendors 2.0.10
But, if you are WC Marketplace then be sure you have removed WC Vendors.
Well, we have resolved this and updated files in wordpress.org
Kindly, delete and re-install WCfM Free once to get updated files.Thank You
- July 11, 2018 at 12:08 pm #26276
Vinz
ParticipantThanks very much, it works ! even with WC vendors 2.0.10 🙂
I have an other problem, in products settings, the tab “Advanced” doesn’t show even if it sets ON on Capability. It’s only with the Vendors, it appears with the admin… I have no logs about that problem.Thanks !
- July 11, 2018 at 12:37 pm #26279
Are you also using WC Vendors Pro? If so, then please be sure you didn’t disable this from there.
- July 11, 2018 at 4:49 pm #26288
Vinz
ParticipantHi, No i’m not using WC Vendors Pro ! And the problem was there when I have tried with WC Marketplace 🙁
Do you have other idea? - July 12, 2018 at 4:39 am #26297
Sorry, I am a bit confused so confirming this again.
We are now talking about Product “Advanced Tab”, right?
You didn’t see this if you installed WC Marketplace!
But it’s appearing perfectly, you may check at our demo – http://wcmp.wcfmdemos.com/my-account/
Between, what is your WCfM and WCfM Ultimate version?
- July 12, 2018 at 9:44 am #26304
Vinz
Yes, the problem is now about product “Advanced Tab” (where you can write about Selling Note, Menu ordering and Reviews).
But I only use WC VENDORS 2 (the latest one and only the free version) and WCFM and WCFM U latest version. WC MARKETPLACE was to test if the problem came from WC VENDORS : the result was : NO
This tab is only visible on WCFM when i’m login as Admin, but not visible when login as Vendor. I don’t understand why, while this option is checked ON on the capability module.I hope not being confused this time !
Vincent
- July 12, 2018 at 10:29 am #26305
Thanks for the details description.
I have just check this and it’s perfectly working for vendors, you may check here – http://wcvendors.wcfmdemos.com/my-account/
Can you please show me your capability page screenshot once!
- July 12, 2018 at 11:20 am #26307
- July 12, 2018 at 12:09 pm #26309
Thanks for the screenshot, that’s really strang!
Can we have a TeamViewer session?
- July 22, 2018 at 10:49 am #26751
Any update ?
- July 24, 2018 at 2:44 pm #26877
Vinz
ParticipantHi, I’m sorry, I didn’t see your previous answer!
No, the problem still here even if I have update your plugin (Free and Ultimate), the Advanced Product section doesn’t appears when we are log-in as a Vendor (only as Admin…)
Have you investigated this issue?Thanks
Vinz
- July 26, 2018 at 3:14 pm #26962
We have checked that but there is nothing except that Capability option to disable that.
Between, what is WCfM and WCfM Ultimate plugin versions?
- The topic ‘Ajax error : No Orders showing’ is closed to new replies.
