Analytics is showing wrong country. Please help fix.
Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM – Analytics › Analytics is showing wrong country. Please help fix.
Viewing 9 reply threads
    • #129317
      eritechdeveloper
      The analytics is showing all hits to the website is from the US, but we are in the UK. and have not published the site yet.
      Capture7
    • #130101
      Keymaster
      It seems your Google Map Key is not authorized to use for this domain. You can check this error in your browser console (see here- https://imgur.com/FE7z5LA)
      That’s why it showing dummy results.
      Thank You!
    • #130145
      eritechdeveloper
      Ok where do I update the API key to make this work, because the Google API key in the Geo search is working fine?
    • #130288
      Keymaster
      Google offers different API for different services. First, make sure you have added/enabled Google Maps API for your project. If it’s already enabled, then you will need to adjust the ‘API Restriction’ field. Read more on this from here- https://wordpress.org/support/topic/referer-not-allowed-map-error/
      Thank You!
    • #131407
      eritechdeveloper
      Will try this and let you know. thanks
    • #131409
      eritechdeveloper
      Hi Buddy,
      Thanks, but still not working, where do I have to input this API Key? because if the API key is not working the other maps on the website will not work, but as you will see in the admin dashboard the API is working fine buddy.
      Please take another look, thanks in advance.
    • #132152
      Keymaster
      Where you can see that in the “admin dashboard”?
    • #132176
      eritechdeveloper
      Hey buddy, I saw it in settings -> Geo location tab. See picture below.
      <script async src=”//s.imgur.com/min/embed.js” charset=”utf-8″></script>
      https://imgur.com/a/sl2IVEh
    • #132402
      Keymaster
      Add the following line in your child themes functions.php or using code snippet plugin and wait for 7days-
      add_filter( 'wcfm_is_allow_wc_geolocate', '__return_false' );
      Thank You!
    • #132834
      eritechdeveloper
      ok thanks, what was the problem?
  • The topic ‘Analytics is showing wrong country. Please help fix.’ is closed to new replies.
