Best Multi Vendor Marketplace Plugin for WordPress › Forums › WC Appointment › appointments issues
- This topic has 9 replies, 4 voices, and was last updated 6 years, 8 months ago by
MarsMars.
- July 31, 2019 at 3:12 pm #74615
MarsMars
I noticed that when a vendor has 2 appointment products .. and he can have two orders for the two products at the same time
to solve this issue according to the wc appointments I need to have a shop staff role
my vendors are freelancers and it will be difficult to ask them to create staff ..
is there a way to have them as vendors and staff at the same time? so they will have one schedule for all the products - July 31, 2019 at 7:08 pm #74648
sdel_nevo
it sounds very similar to the issue I raised here last month
https://wclovers.com/forums/topic/google-sync/
I hope that the guys are able to create a way that vendors can use this without staff, as for the vast majority of UK based businesses this is not going to work
Steve
- August 3, 2019 at 7:30 am #74976
my vendors are freelancers and it will be difficult to ask them to create staff ..– Well, WC Appointments only check availability as per staff availability, not for vendors!
Certainly, we can not change this checking.
- August 4, 2019 at 12:15 am #75100
Atanas Mladenov
I use WCFM Ultimate + WCFM Marketplace to run a multi-vendor booking website and I bought woocommerce appointments 3 days ago. When I create an appointment from backend everything is OK, but when I try creating it from frontend the problem is following:
I go to product-> add new-> choose appointable, fill the name and the price – here everything is OK.
After that when I try setting custom availability from availability field it doesn’t work and all dates in the calendar are unavailable.
I tried demos and there is the same problemThanks in advance,
AtanasAttachments:
You must be logged in to view attached files.- August 5, 2019 at 12:11 pm #75300
What is your WC Appointments and WCFM Ultimate plugins’ version?
- August 5, 2019 at 4:33 pm #75367
Atanas Mladenov
I updated all plugins to latest versions and they started working correctly. Now everything seems okay.
If I have any trouble, I I’ll contact you again.
Thank you,
Atanas
- August 4, 2019 at 10:51 am #75177
MarsMars
ParticipantThanks for your feedback WCFM
is this can be done through custom development- August 5, 2019 at 12:13 pm #75302
MemberNo, Appointment plugin does not have any such prohibition.
As per their suggestion, it will be only possible by add “Staff” role to Vendor’s as well.
- August 5, 2019 at 12:16 pm #75304
sdel_nevo
I take it that means that the vendor will need two logins? one with a vendor account, and then they would need to add them self as a staff member?
if so that’s not going to work for the vast majority of small businesses,on the other hand
if a vendor could also be given “staff” level then that would be fantastic
Steve
