Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM – Ultimate › Approve products befor publishing
- This topic has 14 replies, 2 voices, and was last updated 5 years, 7 months ago by
r_guayaquil.
- February 10, 2020 at 6:24 am #106350
r_guayaquil
Is there an option for the admin to first check and approve the products a vendor wants to publish?
I need to first verify that the vendor meets the publishing requirements.
- February 10, 2020 at 1:29 pm #106384
KeymasterHello,
Thanks for getting in touch with us.
To do this, go to Capability from your admin settings and disable Publish Products and Auto Publish Live Products capability under Products section[ref- https://ibb.co/mFRDVMy%5D.
Next time, when a vendor submits a product, the admin has to approve it from Products page.
Let me know how it goes.
Thanks! - February 10, 2020 at 11:39 pm #106556
r_guayaquil
Thanks for the help!
Does this work even if the vendor upload his products using a csv file?
- February 11, 2020 at 12:07 pm #106639
KeymasterHello,
Yes, this setting will work the same way for CSV upload as well.
Thanks - February 11, 2020 at 11:11 pm #106742
r_guayaquil
Thats awesome! One question. Can i set the capabilities to ony upload products using a csv file and not manually?
- February 12, 2020 at 7:02 pm #106853
No right now that’s not possible. Though it can be custom coded.
One more thing I want to add in this context, there is a limitation in product import. If a vendor exceeds allowed product limit then import button will not appear at all. But if they have products remaining and import csv with products > remaining number of products then the rest of the products will be imported and assigned ‘Pending’ status.
Thanks. - February 28, 2020 at 3:24 am #109138
r_guayaquil
I have product limit to 10 products, but a vendor added 1 product manually and then 14 products using a csv file and now all 15 products are publish.
5 products should be as draft.
You must be logged in to view attached files. - February 28, 2020 at 6:02 pm #109195
KeymasterHello,
Sorry but I couldn’t replicate the issue from my end. It’s working exactly like I explained in my last reply.
Please provide me a temporary access of your site (admin & vendor). Also, don’t forget to mark it as private.
Thanks! - February 29, 2020 at 5:15 am #109267
r_guayaquil
ParticipantThis reply has been marked as private. - March 1, 2020 at 12:59 pm #109399
KeymasterHello,
I tried and it worked perfectly. First I logged in as vendor and exported 14 of the existing products to create my import file. Then, I delete those 14 products and imported again. The result is as expected; all the products gets imported with pending status assigned to them.
You can check that by logging in to your vendor account.
Thanks! - March 2, 2020 at 12:41 am #109476
r_guayaquil
ParticipantThis reply has been marked as private. - March 2, 2020 at 5:13 pm #109552
KeymasterHello
Well, Admin as owner of the site enjoys unrestricted capability so he/she can publish products of vendors even if they used their full quota of products.
In second case, your vendor can publish that one additional product only when they delete the additional drafted products.
Thanks! - March 4, 2020 at 12:10 am #109783
r_guayaquil
I think it would be a nice idea for the vendor to have as many products as he wants as dratf, but can only publish according to his capability.
I hope you guys consider this in the next update.
Thanks a lot for all the help!
- March 4, 2020 at 2:43 pm #109908
KeymasterHello,
There is a risk involved in this. For instance, what if vendors try to cheat the marketplace by continually drafting the products once is hits low or nil inventory stock and in that place publish other products. In that case, they will be able to sell more number of products than their allowed product limit.
That’s why we keep it like this.
Thanks! - March 5, 2020 at 9:30 pm #110137
r_guayaquil
Thanks for explaining 🙂
