Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM – Membership › Assign Membership Rules to Vendor
- This topic has 6 replies, 3 voices, and was last updated 6 years, 11 months ago by
mapmusic.
- September 3, 2018 at 2:05 pm #30673
mapmusic
Maybe I miss something again.
I created membership plans.
I create one feature “Product Limit”.
Where I can assign Product Limit feature to Product limitation for Vendor ?
In Vendor list I see allways 1/inf in Product Limit column.Also can feature has own label ? Or only specific labels are supported ?
You must be logged in to view attached files. - September 4, 2018 at 6:27 am #30729
mapmusic
ParticipantAnyone ?
- September 4, 2018 at 9:13 am #30740
d-n-13
Devs always answers everyone for few days then disappear a day or two applying fixes & enhancements, after they release the new update you will see them active answering everyone, usually they release updates at the start of every week.
Regarding your question,you will have to get WCFM – GROUPS & STAFFS Add-On and add different groups with different abilities then assign each group to a different membership. Check knowledgebase : https://wclovers.com/knowledgebase/wcfm-groups-staffs/
Or you can use the general compatibility setting but usually it is applied to all members. Check KNowledgebase : https://wclovers.com/knowledgebase/wcfm-capability-controller/
Best Regards,
Khalid - September 4, 2018 at 9:16 am #30741
mapmusic
So if I understood correctly, without WCFM – GROUPS & STAFFS is membership add-on not useable ?
- September 4, 2018 at 9:58 am #30742
d-n-13
You need WCFM – GROUPS & STAFFS for compatibility only,
Membership plugin works without it, you can give each membership a different commission and price.
I am not Dev, I’m just a customer, and WCFM – GROUPS & STAFFS is a great Add-On
Thank You.
- September 5, 2018 at 7:06 am #30836
Thanks @d-n-13, really appreciate your cooperation.
Well, Product limit can be set from WCFM Ultimate capability option as well, bu then it will work for all vendors and all membership levels.
If you want to set “Product Limit” at membership level or for individual vendors then WCFM _ Group & Staff essential.
- September 6, 2018 at 3:05 pm #30983
mapmusic
ParticipantAllready obtain license….;)
- The topic ‘Assign Membership Rules to Vendor’ is closed to new replies.
