Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM › Audio file issues
- This topic has 4 replies, 1 voice, and was last updated 6 years, 5 months ago by
sdel_nevo.
- November 19, 2019 at 8:51 pm #92989
sdel_nevo
ParticipantHi Guys
if a vendor inserts an audio file into either the product description or the products short description by using the “Add Media” button, it appears when adding a product, but if the product needs to be edited it is not visible to them.
The audio file is visible when looking via the woocommerce products
I have cleared all caches, disabled all cache plugins but the issue still remains
I have attached two images
I will upload a video shortly outlining the problem
Steve
You must be logged in to view attached files. - November 19, 2019 at 9:38 pm #92998
sdel_nevo
ParticipantThis reply has been marked as private. - November 25, 2019 at 10:49 pm #93942
sdel_nevo
ParticipantHi Guys
have you been able to look into this?
the problem happens even if all caching and CDN settings have been removed/uninstalled
and on a clean install on a testing site
if you require access to my site to investigate I can send you your login details
Steve
- November 27, 2019 at 10:06 pm #94282
sdel_nevo
ParticipantHi Guys
sorry to be a pain, have you been able to take a look at this?
Steve
- December 4, 2019 at 2:24 pm #96005
sdel_nevo
ParticipantHi Guys
really sorry to be a pain.
have you been able to take a look at why audio files in either the product description or short description are not visible to vendors, but appear on the product
Steve
- The topic ‘Audio file issues’ is closed to new replies.
