Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM – Analytics › Improvements/Feature requestes
- This topic has 4 replies, 3 voices, and was last updated 7 years, 10 months ago by
Shhiv Narayan.
- October 11, 2017 at 1:37 pm #14218
Lourenco.cf
now the report off this addon
– Reports by category – don’t work – only show the spinning wheel
– Products more views – don’t appear nothing…
– Search product, inside the reports – dropdown empty
– Sales by date – only can see “order Counts”, and empty values…Add
– Possibility to show multiple products?Thanks
- October 11, 2017 at 5:31 pm #14226
Again this is also seems to me strange. Kindly check here, everything works perfectly here – http://wcmp.wclovers.com/my-account
I think you are facing some caching issue.
WCFM 3.2.0 is a major release and most the core JS/CSS files are updated. Can you please clear your browser cache and check again?
In another browser or private browsing mode also another options.Please know me as I can’t generate such bugs.
Thanks for your patience.
- October 12, 2017 at 4:40 am #14257
Shhiv Narayan
Kindly update your WCFM – Analytics plugin, now it’s very much required.
I will make those changes again for you, don’t worry.
- October 12, 2017 at 11:23 am #14271
Lourenco.cf
ParticipantShhiv,
Works flawlessly!!! Five stars!
Only don’t understand, why the screen for search product is empty, see the screen…Question…is possible analytics by attributes and compare multiple products?
You must be logged in to view attached files. - October 12, 2017 at 4:17 pm #14281
Shhiv Narayan
MemberGreat great !!
Ummm .. I have to check why this box is empty. It’s in Product wise sales report, right?
I want to share you the WCFM – Analytics future road map –
1. Product Compare analytics
2. Product custom taxonomy (e.g. Brand) analytics
3. For admin – vendor store compare analyticsBy attributes, not in plan yet. Actually WooCommerce attribute most use for creating variation and search filter. I will think about it.
It will be really pleasure for me if you give a Five Start, but not here then add it here .. lol
https://wordpress.org/support/plugin/wc-frontend-manager/reviews/Thank you
Shhiv
- The topic ‘Improvements/Feature requestes’ is closed to new replies.
