Diwali
01Day 03Hr 38Min 29Sec
Diwali
Bug with vendor shipping system
Viewing 1 reply thread
    • #28265
      George
      WC Vendors Pro saves the capability status of vendor shipping system in database with ‘yes’ or ‘no’
      If the capability is disabled, the value is ‘yes’, and if is enabled the value is ‘no’.
      But at wc-frontend-manager/views/settings/wcfm-view-wcvendors-settings.php you check the capability status with:
      if( ! WCVendors_Pro::get_option( ‘shipping_management_cap’ ) )
      I think the code should be:
      if( WCVendors_Pro::get_option( ‘shipping_management_cap’ )==’no’ )
      Please check it
    • #28288
      Yeah right, code should be –
      if( WCVendors_Pro::get_option( ‘shipping_management_cap’ ) == ‘yes’ )
      We will definitely correct this in next update.
      Thanks for your cooperation.
  • The topic ‘Bug with vendor shipping system’ is closed to new replies.
