Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM – Marketplace (WooCommerce Multivendor Marketplace) › Bulk vendors import
- This topic has 4 replies, 2 voices, and was last updated 5 years, 1 month ago by
vitoparisi.
- June 7, 2020 at 2:35 pm #139245
vitoparisi
Is there a way to import a list of vendors? I see I can import products but don’t find the same
thanks
- June 7, 2020 at 7:43 pm #139306
- June 8, 2020 at 12:59 am #139340
vitoparisi
ParticipantWhen I click on csv it downloads the file doesn’t allow me to upload one
- June 8, 2020 at 1:20 pm #139508
Avinaba
MemberOh In see, well this isn’t provided by default, however it can be done by creating a custom-addon, by the way what are the fields you want to be imported?
- June 8, 2020 at 1:37 pm #139520
vitoparisi
Participantwell I have 15.000 records and I would like to turn them into basic vendors: https://www.ioeilmiocane.it/servizi-per-cani/
My idea is to import all them and to let users search for vendors based on the merchant category. To give you an example the user could search for:
– vets
– pet shop
– groomer
– breederand based on their search they will have a list of all them
It means that when a new vendors submits his activity he will choose from a dropdown what he does.
This is the standard. And of course there is an exception: the breeder. In this case I would also need to relate the breeder to one (or more) breeds.
Let’ say I am a breeder and I want to sign in. I will check the type of activity and then which breeds I have, like:
– australian sheperd
– pug
– …Hope it makes sense
