Can not find a solution to remove auto created "Canonical" URL
Best Multi Vendor Marketplace Plugin for WordPress › Forums › WC Marketplace › Can not find a solution to remove auto created "Canonical" URL
Viewing 3 reply threads
    • #99780
      Hello all,
      Can I get help to fix/ remove the “Canonical” URL added in the seller’s store links.
      Eg if I visit the URL https://madefromrecycled.com/store/rtistic-ltd/about/ there is a Canonical URL without the “/” which really affect SEO.
      Please suggest solutions to fix it. I really appreciate it.
      Chamara
    • #102987
      Keymaster
      Thanks for getting in touch as sorry for any inconvenience caused.
      WCFM doesn’t add Canonical url. It is coming from another plugin. Are you using any SEO related plugin in your site?
      Let me know.
    • #104858
      Hello there,
      Yes I am. I have Yoast installed.
    • #105438
      Keymaster
      Please share a temporary site access to further debug the issue. Also, don’t forget to mark it as private.
      Regards
  • The topic ‘Can not find a solution to remove auto created "Canonical" URL’ is closed to new replies.
