Best Multi Vendor Marketplace Plugin for WordPress › Forums › WC Marketplace › Can vendors select their preferred payment options?
- This topic has 3 replies, 2 voices, and was last updated 7 years, 7 months ago by
Viewing 3 reply threads
- March 14, 2019 at 1:47 pm #52610
Rishi
Guesthi, is it possible for the vendors to choose their preferred payment options for the products in their store?
Some vendors might want to use only cash or deliver or some might want to use cod and credit cards.
- March 14, 2019 at 4:58 pm #52662
Do you want to restrict one vendor purchase at a time?
Otherwise this will not work!
between, by default there is no such function but can be implemented using custom development ..
- March 23, 2019 at 5:02 am #54128
Pras
GuestHow do you restrict to one vendor purchase at a time?
- March 23, 2019 at 12:16 pm #54185
Please add this code snippet to your child theme’s functions.php –
add_action( 'woocommerce_add_to_cart_validation', function( $is_allow, $product_id, $quantity ) { $product = get_post( $product_id ); $product_author = $product->post_author; //Iterating through each cart item foreach ( WC()->cart->get_cart() as $cart_item_key => $cart_item ) { $cart_product_id = $cart_item['product_id']; $cart_product = get_post( $cart_product_id ); $cart_product_author = $cart_product->post_author; if( $cart_product_author != $product_author ) { $is_allow = false; break; } } if( !$is_allow ){ // We display an error message wc_clear_notices(); wc_add_notice( __( "Well, you already have some item in your cart. First checkout with those and then purchase other items!", "wcfm-ecogear" ), 'error' ); } return $is_allow; }, 10, 3 );Thank you
- The topic ‘Can vendors select their preferred payment options?’ is closed to new replies.
