Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM – Groups & Staffs › Can't Create Separate Categories for Different Groups and Memberships
Tagged: Categories, membership, vendors, WCFM - Groups
- This topic has 8 replies, 3 voices, and was last updated 8 years, 1 month ago by
- April 24, 2018 at 10:07 am #22280
MomentumIsrael1
ParticipantHi Guys,
After purchasing the WCFM – Groups & Staffs Add-On, I created 3 Groups for 3 different Vendor memerbships on my website i.e. http://www.israelvmart.com, I assigned these groups to their membership and add the capability as well. I want to assign selected categories to all the Group, I chose the categories on Capability settings page but when I go to Vendor dashboard of a Member, It shows all the categories to add the products, While it should be only selected category to that particualr Group/Membership.Please see the attached files and let me know if I am doing something wrong or Add-On has a Bug?
You must be logged in to view attached files. - April 24, 2018 at 11:17 am #22285
We have just checked this and didn’t found any such issues there.
Please be sure that vendor is not associated with two groups.
You can check the groups associated vendors, be sure that vendor associated with that group.
- April 24, 2018 at 11:26 am #22291
MomentumIsrael1
ParticipantThis reply has been marked as private. - April 24, 2018 at 11:31 am #22294
Bingal
Which multi-vendor plugin you are using in?
Did you checked, is other group specific capabilities are working for this vendor?
- April 24, 2018 at 11:34 am #22296
Bingal
Opps! I just noticed one thing. Possibly you don’t have WCfM Ultimate, right?
Actually, this capabilities are working only with WCfM Ultimate. Do you have any plan of purchasing that in near future?
If not, then know me. We will give you support of these separately.
- April 24, 2018 at 11:53 am #22299
MomentumIsrael1
ParticipantHi Bingal,
I am using WC Vendor plugin and Yes you’re right I don’t have WCFM Ultimate yet. How can we fix it without WCFM Ultimate?Thanks
- April 24, 2018 at 1:09 pm #22302
You just have to add this code to your site for the purpose –
function wcfmcap_allowed_taxonomies_custom( $allow, $taxonomy, $term_id ) { $wcfm_capability_options = apply_filters( 'wcfm_capability_options_rules', get_option( 'wcfm_capability_options', array() ) ); if( $taxonomy == 'product_cat' ) $taxonomy = 'categories'; $allowed_taxonomies = ( !empty( $wcfm_capability_options['allowed_' . $taxonomy] ) ) ? $wcfm_capability_options['allowed_' . $taxonomy] : array(); if( is_array( $allowed_taxonomies ) && !empty( $allowed_taxonomies ) ) { if( !in_array( $term_id, $allowed_taxonomies ) ) { $allow = false; } } return $allow; } add_filter( 'wcfm_allowed_taxonomies', 'wcfmcap_allowed_taxonomies_custom', 450, 3 );Please know me is this resole the issue for your or not!
- April 25, 2018 at 5:53 am #22325
MomentumIsrael1
I added the code to functions.php but unfortunately its not working. Let me add few more things that can help you to understand the flow:– I deleted all the vendors from the system so that I can add them again.
– I created 3 membership tyep: Freelance, Pro and Advanced.
– Then I created 3 Groups: Grp_freelance, Grp_Pro and Grp_Advanced
– GRP_freelance can’t add any product so I have revoked all the capabilities for him.
– GRP_Pro Vendors can add products only in 1 Category.
– GRP_Advanced can add unlimited products to ANY product category.
– Now I assigned the Groups to their respective memberships.– Now to test the functionalit, First I created a Freelance User, I checked his dashboard and He doesn’t have anything in that means that Group capability is working fine.
– Next, I created another Vendor and Assigned Pro membership to it, Now when I access his account, He can add new products BUT here is the real problem: He can select any Category from the Category list, While They should have access to only 1 category that I choose during GRP_Pro group creation.I hope I’ve clear all the steps now and It will be easier for you guys to sort out the issue. If you need any access to the site, Just let me know.
Note: I am using WC Vendors plugin for Vendors.
- April 27, 2018 at 8:20 am #22421
Thanks for the detailed explanation. I understand your membership setup.
Only factor is category capability is not working, I know why this and already explained you.
But why custom code is not working for you? Did you add this is main theme’s functions.php or in child theme’s ?
Are you comfortable in TeamViewer season? We will check the things and make it working for you.
- The topic ‘Can't Create Separate Categories for Different Groups and Memberships’ is closed to new replies.
