Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM – Ultimate › Cant edit Pictures from product
- This topic has 21 replies, 3 voices, and was last updated 7 years, 4 months ago by
- March 9, 2018 at 11:04 am #20001
Aree
GuestHello, ive found a Problem/Bug … if i try to edit the main Picture of one of my Product (its a variable product) i cant change the Picture. I cant klick remove, i cant add a gallery pic or something. Do you know tjis porblem, i use WCMP with WCFM Ultimate.
- March 9, 2018 at 11:06 am #20002
Aree
GuestOkay i was to fast, no Button is clickable … the Buttons below arent clickable…
- March 9, 2018 at 11:54 am #20003
So you mean, for a variable product on edit you are not able to click on anything, right?
Can you please be sure, there is no JavaScript error in the page, check in Google chrome browser console.
- March 9, 2018 at 3:43 pm #20024
aree
GuestThis reply has been marked as private. - March 9, 2018 at 3:46 pm #20028
aree
GuestI cant klick anything on every Typ of Produkt, it doesnt work on Simple or Variable
- March 9, 2018 at 3:54 pm #20030
aree
GuestThis reply has been marked as private. - March 9, 2018 at 3:57 pm #20032
aree
GuestIf you want u can make you and account on the top right ” Als Verkäufer Anmelden” on
- March 9, 2018 at 4:02 pm #20034
Bingal
This error is nothing, it’s from Chrome.
Please give me a test Vendor access, I want to check this.
- March 9, 2018 at 4:15 pm #20038
aree
GuestThis reply has been marked as private. - March 9, 2018 at 5:57 pm #20044
MemberThank you, we are just looking into this.
- March 9, 2018 at 6:10 pm #20045
I have just tested the thing with a Simple and a Variable Product, but no issues.
I think your browser causing some issues, may be old cache or something else.
Can you please take a try at other PC or another browser.
I will test this a bit more and know you my experience.
Between, you have used that custom code to set all Attributes required, now that’s something dangerous for creating variable products with too many options.
- March 10, 2018 at 9:29 am #20076
aree
GuestOkay, thank you, yes your right, i used the mozilla brwoser and chrome browser, i can edit your porduct but not my own…
Okay i do some more tests.
- March 12, 2018 at 1:04 pm #20214
Aree
GuestOkay, its hard to tell you, but i cant edit Products, beacause ive no button to accept on the end of the Formular.
And its shows not all of the form here a pic:
- March 13, 2018 at 9:40 am #20253
Bingal
KeymasterSnap is not coming.
As I told you, remove that code for restrict all Attributes as required.
It’s a hugh pressure on system, and in general a Product does not comes with 10-15 variation options.
Actually, WC Add-ons is best for this.
- March 13, 2018 at 9:45 am #20254
Bingal
KeymasterBetween, are you facing issue with Simple product as well!
- March 14, 2018 at 2:54 pm #20325
aree
GuestOkay, I have now cleared out the code and now everything works again with the required properties. I really only need one single property as needed property. Is there really no other solution? I would really appreciate it.
- March 14, 2018 at 4:03 pm #20326
aree
GuestThis reply has been marked as private. - March 14, 2018 at 4:50 pm #20327
aree
GuestThis reply has been marked as private. - March 14, 2018 at 6:18 pm #20337
Bingal
KeymasterSure, i will check that.
- March 15, 2018 at 10:57 am #20361
Aree
GuestThis reply has been marked as private. - March 17, 2018 at 11:59 am #20456
Aree
GuestHello, i did the Update, and the Edit Function works fine now!
- March 17, 2018 at 12:28 pm #20458
Wow … that’s something magical.
Between, if you want to use old look then please follow this – https://wclovers.com/forums/topic/wcfm-new-dashboard/
- The topic ‘Cant edit Pictures from product’ is closed to new replies.
