Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM – Marketplace (WooCommerce Multivendor Marketplace) › Can't edit product in site admin dashboard
- This topic has 14 replies, 2 voices, and was last updated 6 years, 7 months ago by
productsexport.
- April 25, 2019 at 6:16 am #59304
productsexport
ParticipantMy site was running and testing fine prior to installing the WCFM plug-in. Now, after I installed the plug-ins, registered a demo vendor, and added a new product for that vendor, I am having a problem.
Description of the problem:
As admin to the site, I can’t access the products edit function anymore from Admin WP Dashboard.. If I click on Edit under the product, the whole website freezes. It takes a few (3-5) minutes to unfreeze again. When It unfreeze, it opens the product edit page to allow me to edit the product. When I am finished editing and click on UPDATE, the same thing happen. The website freezes again for a few minutes. While this happens, no one can browse the website from the front-end.This a major problem for me. I am having so many issues with running your plug ins smoothly. Could it all be related? Your assistance and support in this matter is highly appreciated.
You must be logged in to view attached files. - April 25, 2019 at 7:27 am #59331
productsexport
ParticipantI troubleshot the plug-ins and noticed that this issue only happens when the WOOCOMMERCE FRONTEND MANAGER plug-in is activated.
What can I do to fix this problem? I really need this fixed to utilize your plug-ins fully.
- April 25, 2019 at 7:34 am #59334
productsexport
ParticipantWhen I access the products from the store Manager, I also noticed the <p> tags in the descriptions and other fields.
You must be logged in to view attached files. - April 25, 2019 at 7:40 am #59341
productsexport
ParticipantThis could be related:
When I click on the Marketplace store-manager/settings/#wcfm_settings_form_marketplace_head page, it takes more than 6 seconds to load. That is abnormal for my website as most pages open in less than 2 seconds.
Also, my Query Monitor is showing a PHP error when the page is opened:
Notice Undefined index: input 2
the_content()
wp-content/plugins/wc-frontend-manager/templates/classic/wcfm-content.php:30
apply_filters(‘the_content’)
wp-includes/post-template.php:247
do_shortcode()
wp-includes/class-wp-hook.php:286
do_shortcodes_in_html_tags()
wp-includes/shortcodes.php:196
wp_kses_one_attr()
wp-includes/shortcodes.php:433
wp_kses_attr_check()
wp-includes/kses.php:808
wp-includes/kses.php:1155Attachments:
You must be logged in to view attached files. - April 25, 2019 at 8:06 am #59357
Well, in between WooCommerce updated to 3.6, so you can not compare with early setup.
Now, you have many other plugins and theme, possibly all not yet compatible with WC 3.6
– Now, this is quite impossible due to WCFM, as WCFM no module runs for wp-admin area.
- April 25, 2019 at 9:17 am #59386
productsexport
ParticipantI will check plug-ins one by one and let you know… No fatal erros log found.
- April 25, 2019 at 9:21 am #59388
productsexport
ParticipantSo far I found a conflict between All-in-one-SEO and the Groups plug in. Once I deactivated the All-in-one-SEO the Groups plug-in worked.
- April 25, 2019 at 11:07 am #59432
MemberAre you getting any error at wp-admin -> WooCommerce -> Status -> Logs -> fatal_erros log
- April 28, 2019 at 3:56 pm #59760
productsexport
ParticipantNo errors at wp-admin -> WooCommerce -> Status -> Logs -> fatal_erros log
- April 29, 2019 at 7:50 am #59843
MemberOK, is there any JavaScript error in Google Chrome browser console?
- April 30, 2019 at 10:03 pm #60130
productsexport
ParticipantYes, I’ve got 3 errors
You must be logged in to view attached files. - May 1, 2019 at 4:12 pm #60243
Which caching plugin you are using?
Or, are you using Autoptimize?
- May 1, 2019 at 4:53 pm #60255
productsexport
ParticipantYes I am using Autoptimize and WP Fastest Cache
- May 2, 2019 at 9:37 am #60317
Please disable “Autoptimize” and check once.
Both can be used, but require a basic setup.
Can you please share your site details with me, I will setup this for you – https://wclovers.com/woocommerce-multivendor-customization/Thank You
- May 2, 2019 at 1:01 pm #60387
productsexport
ParticipantI just sent site details
- The topic ‘Can't edit product in site admin dashboard’ is closed to new replies.
