Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM – Analytics › categories filter
- This topic has 11 replies, 3 voices, and was last updated 9 years, 1 month ago by
- September 11, 2017 at 1:40 pm #13168
Sotnas
GuestPré-sales questions
– Categories filter – Is possible? - September 11, 2017 at 9:26 pm #13210
Can you please give us a more details?
Where you want this?
Are you looking for category wise Analytics, if so then definitely possible.
Actually, this will be part of it’s next update.If I am wrong then please correct me.
- September 14, 2017 at 11:23 am #13276
Lourenco.cf
ParticipantThanks for reply.
Only need a query filter in analytics dashboard, for categories…
- September 14, 2017 at 4:10 pm #13281
MemberBut where you want this?
For searching Products easily?Or looking for a separate section as Product to check Category page analytics?
Can you please take screenshot of current Analytics page mention your requirement?
- September 14, 2017 at 5:43 pm #13284
Lourenco.cf
ParticipantThis reply has been marked as private. - September 18, 2017 at 7:11 pm #13475
WCfM Forum
Kindly update WCfM – Analytics to 1.0.2, now it’s even show you Category wise analytics as well.
- September 18, 2017 at 8:12 pm #13482
Lourenco.cf
ParticipantThanks,
great work!
Can i change the order, categories appear before “…by products”?
If so, where.Thanks again
- September 18, 2017 at 8:18 pm #13485
WCfM Forum
There is no such Settings, but it can be achievable by editing the core plugin file.
Are you comfortable in doing so ?
Off course, how you will receive next update?Please know your thoughts
- September 18, 2017 at 8:21 pm #13486
Lourenco.cf
yes i’m comfortable, only tell me where…
Thanks - September 18, 2017 at 8:31 pm #13489
WCfM Forum
GuestBetter, I will send you modified file copy.
You have to just replace that.
- September 18, 2017 at 8:53 pm #13492
Lourenco.cf
ParticipantMany thanks again…!
- September 19, 2017 at 5:00 am #13494
Here is the updated code for you.
You have to replace this file under – “wcfm-analytics/views/”Thank You
- The topic ‘categories filter’ is closed to new replies.
