Best Multi Vendor Marketplace Plugin for WordPress › Forums › WC Marketplace › Checkout User location in Map not working
- This topic has 4 replies, 2 voices, and was last updated 5 years, 10 months ago by
tristantrx.
- June 5, 2020 at 2:06 am #138537
sudesna401
ParticipantI am using the latest version 6.5.0. In the geo location settings, I have activated Checkout User location to enable user’s location input using the map at checkout. But no map is showing. I have used a free open street map. Tried many times. Even in the front end source code on map field is reflecting. please solve & fix it. In addition, use the advantage of getting geolocation API of any browser to fetch user present location lat & long. from that reverse geocode to fetch address. it will be very usefull for user.
You must be logged in to view attached files. - June 5, 2020 at 2:12 am #138540
tristantrx
ParticipantI was having the same issue. You need to change settings in Woocommerce for this to work since the update.
Not 100% sure what I changed, but it is working perfectly now.
If you need help, I’ll be happy to try by comparing settings
- June 5, 2020 at 5:25 pm #138788
sudesna401
Participantyes please share the settings so that I can fix it.
- June 5, 2020 at 10:48 pm #138909
sudesna401
ParticipantI fixed it by changing to default to billing instead of force to billing address
You must be logged in to view attached files. - June 6, 2020 at 10:03 pm #139139
tristantrx
ParticipantThe above answer may have been what fixed it for me also, as I have this option selected.
- The topic ‘Checkout User location in Map not working’ is closed to new replies.
